A stunning PC needs suitably stunning visuals, so Zen AiO S is equipped with up to a glorious 4K/UHD (3840 x 2160) IPS 10-point multi-touch display that not only shows every minute detail, but also has vividly-lifelike colors and wide 178° viewing angles. No matter how you look at it, the screen of Zen AiO S is a marvel.
The screen on Zen AiO S has a wide color gamut of up to 82% NTSC, 85% Adobe RGB and 100% sRGB. This is simply a technical way of saying that Zen AiO S reproduces more colors, more accurate colors, and colors that are richer and more vivid than a standard display.
Zen AiO S is a precision-crafted masterpiece inspired by the spirit of Zen. It combines the simplicity of pure aluminum with the sophistication of advanced technology to create timeless yet practical beauty for your home. The elegant and incredibly-slim anodized aluminum cover and integral stand are hewn from solid aluminum. Zen AiO S is beautifully-finished in stunning Icicle Gold, enhanced with the iconic and unique spun-metal finish with its Zen-inspired concentric-circle pattern was used. To reduce distractions to the minimum, a flawless edge-to-edge glass display that blends seamlessly with the bezel to give you an uninterrupted viewing area. It's this attention to the smallest details that set Zen AiO S apart.
Zen AiO S uses only the latest and most advanced components, so you and your family can enjoy effortless performance for any task, along with state-of-the-art home entertainment that's rich and immersive. Using powerful processors, combined with uDDR4 memory and lightning-fast PCIe Gen 3 x 4 SSD storage, Zen AiO S has power to spare for instant responsiveness and ultra-smooth multitasking. Dedicated NVIDIA GeForce GTX 960M gaming-grade graphics ensure you'll enjoy superb stutter-free HD movies and videos in vivid, lifelike colors, or play even the very latest games at full resolution with high quality settings.
Zen AiO S is designed for the ultimate home entertainment, using a total of 6 speakers to deliver rich and clear full-range sound. Each 8-Watt stereo channel uses three powerful speakers located at either side of Zen AiO S, giving fully-realistic stereo separation and a total of 16 Watts of pure, undistorted sound for an amazingly lifelike entertainment experience. You won't believe how good Zen AiO S sounds, whether you're watching the latest blockbuster, playing games or relaxing to your favorite tunes.
Immerse yourself in detail
A stunning PC needs suitably stunning visuals, so Zen AiO S is equipped with up to a glorious 4K/UHD (3840 x 2160) IPS 10-point multi-touch display that not only shows every minute detail, but also has vividly-lifelike colors and wide 178° viewing angles. No matter how you look at it, the screen of Zen AiO S is a marvel. -
Richer, more accurate colors
The screen on Zen AiO S has a wide color gamut of up to 82% NTSC, 85% Adobe RGB and 100% sRGB. This is simply a technical way of saying that Zen AiO S reproduces more colors, more accurate colors, and colors that are richer and more vivid than a standard display. -
A true modern masterpiece
Zen AiO S is a precision-crafted masterpiece inspired by the spirit of Zen. It combines the simplicity of pure aluminum with the sophistication of advanced technology to create timeless yet practical beauty for your home. The elegant and incredibly-slim anodized aluminum cover and integral stand are hewn from solid aluminum. Zen AiO S is beautifully-finished in stunning Icicle Gold, enhanced with the iconic and unique spun-metal finish with its Zen-inspired concentric-circle pattern was used. To reduce distractions to the minimum, a flawless edge-to-edge glass display that blends seamlessly with the bezel to give you an uninterrupted viewing area. It's this attention to the smallest details that set Zen AiO S apart. -
Extreme beauty, extreme performance
Zen AiO S uses only the latest and most advanced components, so you and your family can enjoy effortless performance for any task, along with state-of-the-art home entertainment that's rich and immersive. Using powerful processors, combined with DDR4 memory and lightning-fast PCIe Gen 3 x 4 SSD storage, Zen AiO S has power to spare for instant responsiveness and ultra-smooth multitasking. Dedicated NVIDIA GeForce GTX 960M gaming-grade graphics ensure you'll enjoy superb stutter-free HD movies and videos in vivid, lifelike colors, or play even the very latest games at full resolution with high quality settings. -
Incredible sound, awesome entertainment
- ASUS Zen AiO Pro Z220ICUT - all-in-one - Core i5 6400T 2.2 GHz - 8 GB - HDD 1 TB - LED 21.5"
- Personal computer - all-in-one
- Processor
- Intel Core i5 (6th Gen) 6400T / 2.2 GHz (, up to 2.8 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- No optical drive
- Card Reader
- 2 in 1
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- OS Provided
- Windows 10 Home 64-bit Edition
- Golden
- 58.5 cm x 9 cm x 43.4 cm
- 6.2 kg
- Personal computer
- Product Form Factor
- All-in-one
- Golden
Processor / Chipset
- CPU
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Card Reader
- 2 in 1 card reader
Monitor
- Monitor Type
- LED
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Audio Output
- Sound Output Mode
- Stereo
- Speakers Included
- 2 x right / left channel
Input Device
- Mouse, keyboard
Keyboard
- Connectivity
- Wireless
Mouse
- Connectivity
- Wireless
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x SO-DIMM 260-pin
- 1 x USB-C 3.1 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 4 x USB 3.0 , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x USB 2.0
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power adapter
- Power Provided
- 120 Watt
Operating System / Software
- OS Provided
- 58.5 cm
- 9 cm
- 43.4 cm
- 6.2 kg
