Asus Z170 PRO GAMING/AURA Intel Z170 S1151 DDR4 M.2 USB3.1 ATX
Quicklinx: C9BHWS00 Mfr#: Z170 PRO GAMING/AURA
The world's first 3D-printing-friendly motherboard with patent-pending mounting design
  • LGA1151 socket for 6th-generation Intel® Core™ i7 / Core i5 / Core i3, Pentium® and Celeron® processors
  • Dual DDR4 3466 (OC) support
  • True gaming aesthetics: 3D-printing friendly and Aura RGB lighting
  • Easy and stable overclocking: Pro Clock technology, 5-Way Optimization and 2nd-generation T-Topology
  • SupremeFX: Flawless audio that makes you part of the game
  • Sonic Radar ll: Scan and detect your enemies to dominate
  • Top-speed protected networking: Intel Gigabit Ethernet, LANGuard and GameFirst IV
  • RAMCache: Speed up your game loads
  • Ultra-speedy transfers for faster gaming: USB 3.1 Type-A/C & M.2
  • Gamer's Guardian: SafeSlot, highly-durable components and smart DIY features
  • Customize your way
    As a gamer, you crave to be first - and Z170 Pro Gaming/Aura is the world's first 3D printing-friendly motherboard, with a patent-pending mounting design that enables easy mounting of your own 3D-printed parts! Create color-matched custom nameplates, and then illuminate your passion with Aura, the ASUS-exclusive LED-illumination technology that lights up an endless spectrum of color combinations, plus loads of fun effects. Customizable. Colorful. Commanding. Create your own vision, with Z170 Pro Gaming/Aura.
  • Make it your own
    Z170 Pro Gaming/Aura is the world's first motherboard with a 3D printing-friendly design. The patent-pending mounting design gives you the exclusive freedom to mount 3D-printed parts with M.2 nuts. You can download, design and print your own 3D parts and then integrate them seamlessly into your Z170 Pro Gaming/Aura build. Create and print personalized nameplates to brand your rig, or design your own protection armor or cable-management solution - it's up to you. And because you're printing your own custom 3D parts, it's easy to create perfect color-matched aesthetics every time!
  • Light up as easy as RGB
    Customize your own favorite LED effects with Aura, the intuitive lighting-control software, to cast a stunning multi-color glow across your build via the motherboard's powerful built-in RGB LEDs! Fire up Aura and then enjoy the creative freedom of 12 different lighting schemes. You're even able to customize the frequency and direction, and sync your lighting style with the ever-growing portfolio of Aura-capable gear.
  • Scan and detect to dominate
    Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill, plus Audio Enhancement technology clarifies every last sound - so you hear the distant sound of enemy footsteps and become the hunter, not the hunted!
  • More throughput, less CPU usage and great gaming experiences
    Featuring the very latest Intel Ethernet (I219-V) for faster, smoother gaming - always. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay.
  • Team up to banish lag
    GameFirst IV optimizes network traffic for faster, lag-free online gaming - and now we've added Multi-Gate Teaming to team all your networks for maximum bandwidth and the smoothest-ever gameplay. You'll also enjoy all-new Intelligent mode, which automatically compiles a database by parsing new app data to ensure that every game is optimized for the best performance.
ASUS Z170 PRO GAMING/AURA - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3100 MHz (O.C.), 3200 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
SupremeFX
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2 - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Rapid Storage Technology
1 x HDMI , 1 x VGA , 1 x DVI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 , 1 x USB-C , 4 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TurboV, NVIDIA 2-way SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, Fanless Design Heatsink, SupremeFX Shielding technology, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, Dual Intelligent Processors 5, LANGuard, Sonic Radar II, USB 3.1 Boost, ASUS PRO Clock Technology, GameFirst IV, ASUS Gamer's Guardian, AURA RGB Lighting Control, ASUS SafeSlot, 3D printing friendly
Cable ties, cable labels, 1 x M.2 screw, I/O back cover
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS Auto Tuning, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, ASUS Turbo App, Antivirus (OEM version), Media Streamer, ASUS RAMCache, ASUS EZ Flash 3
Plug and Play
30.5 cm
24.4 cm
