Asus Z170-DELUXE Intel Z170 LGA1151 DDR4
Quicklinx: BJ05WS00 Mfr#: Z170-DELUXE
  • Bluetooth 4.0
  • IEEE 802.11n
  • Bluetooth 3.0
Unleash performance with one click and exclusive OC design, plus unparalleled connectivity with 3x3 802.11ac Wi-Fi
5-Way Optimization: One click optimizes your entire system with a dedicated water-pump header on board
ASUS Pro Clock Technology: Extends base clocks and improves stability for extreme overclocking
6 USB 3.1 onboard: 5 Type-A ports and 1 reversible Type-C port
Dual 32Gbit/s ultra-fast M.2 x4: Onboard and PCIe add-in card
Hyper Kit: Bundled for instant U.2 support
One click overclock and cooling, done!
Get performance, efficiency, digital power, fan control and even networking and audio tuning tailored for you
5-Way Optimization at your disposal it takes just one click to tune complex settings — for instant, highly-controllable performance boosts! Our exclusive technology dynamically optimizes essential aspects of your system based on real-time use, so you get superb CPU performance, everyday energy savings, ultra-stable digital power, cool and quiet fans and even networking and audio settings that are tailored for the apps that you are using. In short, 5-Way Optimization ensures that your PC is perfect for gaming, entertainment, productivity or just about anything else!
Games run swiftly and smoothly with high performance, prioritized bandwidth and vivid sound.
Fans stay whisper-quiet for everyday computing, and ensure extreme cooling efficiency when gaming.
Stutter is eliminated for smooth-running apps, even under heavy loading.
Energy waste is reduced so you'll save money
TPU
Unleash your PC's full performance with a simple two-phase onboard switch or the ASUS AI Suite 3 utility! The TurboV Processing Unit (TPU) offers precise voltage control and advanced monitoring for the CPU and the graphics card, enabling great freedom to adjust CPU frequencies and ratios for optimized performance and to exploit the potential out of your graphics card
OC Design- ASUS PRO Clock technology
A dedicated base-clock (BCLK) generator designed for 6th-generation Intel® processors that allows overclocked base clock frequencies up to or beyond 400MHz*. This custom solution works in tandem with the ASUS TurboV Processing Unit (TPU), to enhance voltage and base-clock overclocking control — providing an exciting new way to boost performance to extreme heights
DDR4 overclocking strength in numbers
Second-generation ASUS T-Topology enables DDR4 memory overclocking to reach new heights: over DDR4-3733MHz with all memory slots populated. Featuring a customized trace layout for reduced crosstalk and coupling noise, our second-generation T-Topology ensures time-aligned signal transfer for improved memory stability and compatibility.
Native M.2/NVMe PCIe RAID support for lightning fast storage speeds!
Not satisfied with single storage device read/write speeds? Then join the fast lane and build a RAID 0 array using two PCIe storage drives to enjoy data transfers at lightning speed!
Fast storage speed with SATA Express
Current SSDs devour up to 550MB/s bandwidth, which is close to saturation point for SATA 6Gbit/s connections. Backwardly compatible with up to two SATA drives, SATA Express is the next-generation connectivity standard — and ensures that you and your system won't get left behind.
Speed up with onboard M.2 up to 32Gbit/s
With x4 PCI Express 3.0/2.0 bandwidth, M.2 supports up to 32Gbit/s data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible.
Ultimate-speed 10Gbit/s with six USB 3.1 onboard
With five USB 3.1 Type-A ports, and one reversible USB 3.1 Type-C, you'll experience data-transfer speeds of up to 10Gbit/s — or twice as fast USB 3.0. USB 3.1 is completely backward-compatible with your existing USB devices, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 Boost technology automatically accelerates USB 3.1 performance even further!
  • Overclock your way
    With the Energy Processing Unit (EPU) you'll enjoy real-time, system-wide power savings. EPU detects and adjusts power consumption according to the PC's needs - automatically. This creates an extreme energy-saving scenario by shutting down unused extra I/O controllers and reduces the graphics cards' power level while you're away, so the PC consumes only the energy it needs - and not a drop more! And with the thermal sensors and hardware-level 4-pin/3-pin PWM/DC mode detection, every fan achieves excellent balance of cooling performance and low noise! The motherboard also features intelligent CPU-power-draw detection with ASUS DIGI+ Power Control, increasing overclocking potential, enhancing system stability, and improving power efficiency with superior flexibility and accurate control. Moreover, a dedicated base-clock (BCLK) generator enhances voltage and base-clock overclocking control - providing an exciting way to boost performance to extreme heights. And finally, the second-generation ASUS T-Topology enables DDR4 memory overclocking to reach new heights: over DDR4-3733 MHz with all memory slots populated. Featuring a customized trace layout for reduced crosstalk and coupling noise, the second-generation T-Topology ensures time-aligned signal transfer for improved memory stability and compatibility.
  • Ultrafast transfer speed
    This motherboard boasts extra fast storage speed with SATA Express and, with x4 PCI Express 3.0 / 2.0 bandwidth, it supports high data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible. With five USB 3.1 Type-A ports, and one reversible USB 3.1 Type-C, you'll experience unbelievably high data-transfer speeds. USB 3.1 is completely backward-compatible with your existing USB devices, and you'll be all set for USB 3.1's breakneck speeds.
  • Game with confidence
    Power pre-regulator reduces power-input noise to ensure consistent performance, while audio shielding ensures precision analog/digital separation and greatly reduced multi-lateral interference. Separate layers for left and right tracks ensure both channels deliver consistent, equal quality of sound for your gaming experience. Z170-DELUXE also features Intel Ethernet for faster, smoother gaming. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay!
  • Extreme stability
    5X Protection II employs outstanding components and excellent circuit design to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build. The featured ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors ensuring a more reliable connection and better throughput, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges. And an exclusive circuit design with built-in voltage regulators serves to protect your motherboard from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
ASUS Z170-DELUXE - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600, 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
1 x USB-C + 5 x USB 3.1 + 1 x USB 3.0 + 1 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
512 MB
Audio
Audio Codec
Realtek ALC1150
DTS Connect, DTS Studio Sound
LAN
Network Controller
Intel I219V / I211-AT
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 4 x PCIe x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
Intel Rapid Storage Technology
1 x DisplayPort , 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 1 x USB 3.0 , 5 x USB 3.1 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x USB 2.0 , 1 x USB-C , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), Loss-less content protection technology, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, Fanless Design Heat-pipe, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Onboard Button, ASUS Wi-Fi GO!, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, DirectKey, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O, anti-pop function, Turbo LAN, ASUS Fan Xpert 3, Dual Intelligent Processors 5, LANGuard, Memory O.C. Design, USB 3.1 Boost, 16+4+2 Phase Power Design, ASUS Crystal Sound 3, ASUS PRO Clock Technology, ASUS 5X Protection II
I/O back plate, 1 x M.2 screw, ASUS 3T3R Wi-Fi moving aerials, M.2 X4 bracket, ASUS Hyper Kit
6 x Serial ATA cable , 1 x SLI bridge
Software Included
ASUS Auto Tuning, ASUS AI Charger, ASUS AI Charger+, ASUS AI Suite III, ASUS Turbo App, Mobo Connect, PC Cleaner, Media Streamer, HyStream
Plug and Play
30.5 cm
24.4 cm
