Product
Asus Xonar U5 5.1 Channel USB Soundcard and Headphone Amplifier
Quicklinx: 9SHTWS00 Mfr#: XONAR U5
  • Windows 8 (32/64 bits)
Compact 5.1-channel USB sound card and headphone amplifier with 192kHz/24-bit HD sound and Sonic Studio suite
  • True 5.1-channel HD (192kHz/24-bit) surround sound from a compact USB-powered device
  • 104dB signal-to-analog ratio (SNR) ensures pure sound
  • Sonic Studio provides complete control over loads of sound technologies
  • Perfect Voice technology eliminates noises for clear in-game communications
  • Independent mic and master-volume controls for instant in-game adjustments
  • Integrated headphone amplifier provides clear, detailed sound for an immersive audio experience
A compact audio solution for incredible sound
Xonar U5 is a compact 5.1-channel USB sound card designed to provide PC gamers with high quality audio for games, music and movies. It follows in the footsteps of the award-winning Xonar U7 - providing you with strong and clear sound via headphones, and producing more impactful and detailed audio than onboard hardware. The Xonar U5 has no standalone power supply and connects to your PC via USB, allowing you to instantly plug-in without having to open the PC case.
Take complete control of your audio with Sonic Studio
Xonar U5 features the latest Sonic Studio software suite, so you have full control over every audio setting ranging from equalization (EQ) to 5.1-speaker level-balancing. Sonic Studio has a single navigation page that puts everything in front of you, with an intuitive point-and-click interface that allows you to pre-set audio profiles to suit different audio requirements.
  • A compact audio solution for incredible sound
    Xonar U5 is a compact USB sound card designed to provide PC gamers with high quality audio for games, music and movies. It provides you with strong and clear sound via headphones, and producing more impactful and detailed audio than onboard hardware. The Xonar U5 has no standalone power supply and connects to your PC via USB, allowing you to instantly plug-in without having to open the PC case.
  • Take complete control of your audio with Sonic Studio
    Xonar U5 features the latest Sonic Studio software suite, so you have full control over every audio setting ranging from equalization. Sonic Studio has a single navigation page that puts everything in front of you, with an intuitive point-and-click interface that allows you to pre-set audio profiles to suit different audio requirements.
  • Incredible input-noise reduction from Perfect Voice
    Unlike noise-reduction technologies that rely on inverse phase noise cancellation, Xonar U5's Perfect Voice technology uses advanced algorithms to separate ambient noise from speech. The result is crystal clear in-game voice communication, so you can be heard even in noisy gaming environments like LAN parties.
  • Enjoy powerful audio quality from a compact and portable device
    The compact and lightweight Xonar U5 features high audio quality, a signal-to-noise ratio (SNR) and true surround sound for true high-definition output and consistent quality across all surround channels. Go big on audio with a sound card this small!
  • Pumps up every sound detail with the integrated headphone amplifier
    Xonar U5 includes a headphone amplifier that supports headphones all the way - so you can plug in some seriously powerful gaming headsets to hear every in-game detail!
  • Dedicated microphone and master volume controls
    Dedicated controls let you tweak audio settings without interrupting your game - you can quickly adjust master and microphone volumes without pausing or entering menus. The master volume controls even doubles as an instant switch for selecting between headphone output and speakers with just a simple click.
ASUS Xonar U5 - sound card
Sound card
Enclosure Type
External
Interface Type
USB
8 cm x 13.8 cm x 2.5 cm
Signal Processor
CM6631A
Sound Output Mode
5.1 channel surround
DAC Resolution
24-bit
Sample Rate
44.1 kHz (min) - 192 kHz (max)
Signal-To-Noise Ratio
104 dB
Hardware Controls And Indicators
Volume control, output select
Apple MacOS X, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1, Windows 10 (32/64 bits)
Sound card
External
Interface Type
USB
8 cm
13.8 cm
2.5 cm
Processor / Memory
Signal Processor
CM6631A
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
104 dB
Frequency Response
10 - 44000 Hz
Headphone Amplifier, Perfect Voice
ASIO
1 x USB - 4 pin USB Type B , 1 x headphones - mini-phone stereo 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone stereo 3.5 mm , 1 x speakers (front surround) - mini-phone stereo 3.5 mm , 1 x speakers (rear) - mini-phone stereo 3.5 mm , 1 x audio line-in/microphone - mini-phone stereo 3.5 mm , 1 x SPDIF output - RCA
1 x S/PDIF optical adapter , 1 x USB cable
Software
Drivers & Utilities, Sonic Studio
