Your basket is empty
Asus Xonar Phoebus ROG Gaming Sound Card Set
Quicklinx: 82TSWS00 Mfr#: XONAR_PHOEBUS
Interface: PCI Express x1
Sound Output Mode: 7.1 channel surround
£116.84 ex VAT
£140.20 inc VAT
Command Your Way to Victory!
ASUS Xonar team is launching world's first ROG gaming soundcard set, Xonar Phoebus , named after the Greek God of Sun and Music, brings to you exclusive noise reduction ROG command technology for seamless communication, hassle-free user experience with brand new Xonar audio center and gamer-focused control box for easy control and command. With decades of experience in perfecting hyper-grounding technology and leveraging top-notch components, Xonar promises to deliver premium audio quality through 118dB SNR for gamers to command their way to victory!
  • ROG Command Technology effectively reduces up to 50% of environmental noise
  • Embrace exceptional sound quality for the win with 118dB SNR clarity and headphone amplifier
  • Control box within easy reach for instant volume tuning and headset connections
  • Enjoy effortless adjustment with new Xonar Audio Center
  • Realistic surround and enhanced sound thanks to Dolby® Home Theater V4 and the GX3.0 game audio engine
ROG Command Technology: Effectively reduces up to 50% environmental noise
ROG Command Technology leverages special micro-mic design to reduce up to 50% of environmental noise, helping gamers to win with seamless communication!
How It Works
  • With external microphone: A smart algorithm analyzes sound detected by both the external microphone and one of the micro-mics on the control box to filter environmental noise.
  • Without external microphone: Array microphones on the control box form a virtual 30?cone of precise voice capture
Embrace Exceptional Sound Quality: With 118dB SNR clarity and a headphone amplifier
  • Bask in game music and get the drop on opponents with improved audio positioning!
  • 118 dB SNR Breathtaking Clarity: 4X clarity than other competing sound cards
  • Hyper Grounding Technology: Noise-blocking multi-layer PCB designed with decades of ASUS professional layout experience.
  • Top Grade Components Selection: EMI Shield, High fidelity PCM1796 DAC, TPA6120A2 headphone amp and more!!
  • Headphone Amplifier: Optimized up to 600 ohms with 3 different gain settings
Control Box with Easy Reach: For instant volume tuning and headset connections
  • Easy Connections on Desk: With any headset or microphone
  • Instant Volume Tuning: With volume turn knob and one-click-to-mute button
  • I/O Ports Lights: Lights up in green light for headphone out and red light for microphone in
Enjoy Effortless Adjustments: With new Xonar Audio Center
  • Instant Volume/ Effects/ Modes Reach With one click access to all features favored by gamers
  • Input/ Output Setting Bar: Hassle-free output/input setup and enable rich features
Realistic Surround and Enhanced Sound: Thanks to Dolby Home Theater V4.0 and GX3.0 Game Audio Engine
  • Dolby Home Theatre V4.0: Benefit gamers with latest sound enhancement and adjustment technology. Benefit gamers with most realistic virtual surround sound
  • GX3.0 Game Audio Engine: Better compatibility with legacy EAX gaming audio. Benefits gamers with immersive sound enhancements
  • Output Signal-to-Noise Ratio (A-Weighted): 118dB
  • Input Signal-to-Noise Ratio (A-Weighted): 118dB for line-in
  • Output Total Harmonic Distortion + Noise at 1kHz: 0.00039%
  • Input Total Harmonic Distortion + Noise at 1kHz: 0.0003%
  • Frequency Response (-3dB, 24-bit/96kHz input ): <10Hz to 48kHz
  • Output/Input Full-Scale Voltage Out-put : 2.2Vrms (3Vp) In-put : 2.0Vrms (2.82Vp) / Headphone : 7Vrms (9.9Vp)
  • Headphone Impedance: Optimized for 32~600O
  • PCI-Express 1.0 or above bus compatible
  • Audio Processor: C-Media CMI8888DHT High-Definition Sound Processor (Max. 96KHz/24bit)
  • D-A Converter of Digital Sources: Texas Instruments PCM1796*2 for Front out and Headphone / Cirrus logic CS4362A for 6 channels / Texas Instruments TPA6120A2 for Headphone Amplifier
  • A-D Converter for Analog Inputs: Cirrus Logic CS5381 for Line In
  • Analog Playback Sample Rate and Resolution: 44.1K/48K/88.2KHz/96KHz/176.4KHz/192KHz @ 16/24bit for all channels
  • Analog Recording Sample Rate and Resolution: 44.1K/48K/88.2KHz/96KHz/176.4KHz/192KHz @ 16/24bit
  • S/PDIF Digital Output: 44.1K/48K/88.2KHz/96KHz/176.4KHz/192KHz @ 16/24bit
  • ASIO 2.0 Driver Support: 44.1K/48K/88.2KHz/96KHz/176.4KHz/192KHz @ 16/24bit
  • Analog Output Jack: 3.50mm mini jack *5 (Headphone /Front/Side(combo with SPDIF) /Center-Subwoofer/Rear)
  • Analog Input Jack: 3.50mm mini jack *2 (Line-In/Mic-In)
  • Other line-level analog input (for CD-IN/TV Tuner): Aux-In (4-pin header on the card)
  • Digital S/PDIF Output: Optical Connector supports 192KHz/24bit (Combo with Side jack) additional SPDIF-out header for HDMI audio output
  • Front-Panel Audio Header: Supports headphone jack-detection, automatically switch audio output from back-panel to front
  • Driver Features: Windows7/ Vista/XP(32/64bit)/MCE2005
ASUS ROG Xonar Phoebus - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI Express x1
Signal Processor
CMI8888DHT
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
44.1 kHz (min) - 192 kHz (max)
Signal-To-Noise Ratio
118 dB
Hardware Controls And Indicators
Gain control
Microsoft Certification
Compatible with Windows 7
Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista, Microsoft Windows XP (32/64 bits)
Sound card
Internal
Interface Type
PCI Express x1
Processor / Memory
Signal Processor
CMI8888DHT
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
118 dB
Frequency Response
10 - 48000 Hz
Gain control
Built-in amplifier, gold plated connectors, ROG Command Technology, Hyper Grounding Technology, illuminated connectors, Smart Volume Normalizer, Xear Surround Headphone, Magic Voice, FlexBass
Dolby Home Theater v4, DirectSound3D GX 3.0, ASIO 2.2
Audio Modes
Playback: 24-bit 192 kHz , Record: 24-bit 192 kHz
1 x microphone - mini-phone 3.5 mm , 1 x headphones - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x speakers (front surround) - mini-phone 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone 3.5 mm , 1 x speakers (rear) - mini-phone 3.5 mm , 1 x speakers (side)/SPDIF output - mini TOSLINK , On supplied cable: 1 x SPDIF output - TOSLINK , On supplied cable: 1 x headphones - mini-phone 3.5 mm , On supplied cable: 1 x microphone - mini-phone 3.5 mm , 1 x audio line-in - 4 PIN DIN
Control box
1 x TOSLINK to mini TOSLINK adapter
Software
Drivers & Utilities, ROG Xonar Audio Center
Asus Xonar Phoebus ROG Gaming Sound Card Set Bundle deal on Asus Xonar Phoebus ROG Gaming Sound Card Set
£132.85
saving £6.92
Resources
The following resources are available for the Asus Xonar Phoebus ROG Gaming Sound Card Set
Brand: Asus
Price Range Ex VAT: 100 - 150
