Your basket is empty
Asus Xonar D2 7.1 PCI Ultimate Theatre & Gaming Soundcard 118Ddb SNR Provides Hi-Fi Class Audio
Quicklinx: 6C5QWS00 Mfr#: XONAR D2/PM/A
Interface: PCI
Sound Output Mode: 7.1 channel surround
£93.70 ex VAT
£112.44 inc VAT
ASUS Xonar D2 audio card, dedicated to be the best audio card for gaming and home entertainments, provides unprecedented 118dB In/Out SNR audio quality and features for games, music and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2 is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Center, which you will never have with onboard audio or other sound cards!
ASUS Xonar D2/PM - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI
Signal Processor
ASUS AV200
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
44.1 kHz (min) - 192 kHz (max)
Signal-To-Noise Ratio
118 dB
Microsoft Windows XP, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista
Sound card
Internal
Interface Type
PCI
Processor / Memory
Signal Processor
ASUS AV200
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
118 dB
DirectSound, EAX 2.0, EAX 1.0, A3D 1.0, ASIO 2.0, Dolby Digital Live, DTS Connect, Dolby Pro Logic IIx, DTS Neo:PC, High Definition Audio
Audio Modes
Record: 24-bit 192 kHz , Playback: 24-bit 192 kHz
1 x audio line-out - mini-phone 3.5 mm , 1 x speakers (side surround) - mini-phone 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone 3.5 mm , 1 x speakers (back surround) - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x SPDIF output - TOSLINK , 1 x SPDIF input - TOSLINK , 1 x MIDI - 4 pin MPC , 2 x audio line-in - 4 pin MPC , On supplied cable: 1 x MIDI - 5 PIN mini-DIN , On supplied cable: 1 x MIDI - 5 PIN mini-DIN
1 x audio (optical) adapter , 1 x audio (optical) cable , 1 x audio cable , 1 x MIDI adapter cable , 1 x MIDI panel
Software
Drivers & Utilities, CyberLink PowerDVD 7, Cakewalk SONAR LE, Ableton Live Lite, Cakewalk Project5 LE, Cakewalk Dimension LE
Additional Requirements
CD-ROM, adjacent PCI slot
System Requirements Details
1.4 GHz - RAM 256 MB - HD 60 MB
Asus Xonar D2 7.1 PCI Ultimate Theatre & Gaming Soundcard 118Ddb SNR Provides Hi-Fi Class Audio Bundle deal on Asus Xonar D2 7.1 PCI Ultimate Theatre & Gaming Soundcard 118Ddb SNR Provides Hi-Fi Class Audio
£109.71
saving £8.98
Interface: PCI
Brand: Asus
Price Range Ex VAT: 50 - 100
