Product
Brand
Asus X99-PRO/USB3.1 S2011 Intel X99 DDR4 USB3.1 ATX
Quicklinx: B62JWS00 Mfr#: X99-PRO/USB3.1
  • Bluetooth 4.0
  • IEEE 802.11n
Unmatched performance, fast 802.11ac Wi-Fi and ultra-fast USB 3.1 onboard for your awesome X99 build.
  • Ultra-fast 10Gb/s USB 3.1 built in to the board
  • Patent Pending OC Socket - Drive CPU and DDR4 performance beyond all expectations!
  • 5-Way Optimization by Dual Intelligent Processors 5 - One click overclock and cooling, done!
  • Dual 32Gb/s ultrafast M.2 x4 (onboard and PCIE add-in card)
  • Crystal Sound 2 - Flawless audio that makes you part of the game!
  • ASUS HomeCloud with 2x2 802.11ac Wi-Fi - Access your PC remotely and stream multimedia content anywhere, anytime"
ASUS X99-PRO/USB 3.1 - motherboard - ATX - LGA2011-v3 Socket - X99
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7 Extreme Edition, Core i7
Max RAM Size
64 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 1 x SATA Express port, 2 x M.2
USB / FireWire Ports
2 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC1150
DTS Connect, High Definition Audio, DTS UltraPC II
LAN
Network Controller
Intel I218V
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 8 x 7pin SATA, 2 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 2 x USB 3.1
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x SPDIF out - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
ASUS EZ Flash 2, USB BIOS Flashback, UEFI BIOS
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS 8 Phase Power Design, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Smart Response Technology, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Onboard Button, ASUS USB Charger+, ASUS Wi-Fi GO!, Disk Unlocker, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, ASUS Stainless Steel Back I/O, ASUS O.C. Tuner, anti-pop function, Turbo LAN, ASUS Crystal Sound 2, ASUS Fan Xpert 3, Dual Intelligent Processors 5, Intel Rapid Recovery Technology, ASUS 4 Phase DRAM Power Design, Memory O.C. Design, ASUS OC Socket, USB 3.1 Boost
I/O back plate, ASUS 2T2R Wi-Fi moving aerials, M.2 X4 bracket
6 x Serial ATA cable , 1 x SLI bridge
Software Included
ASUS EZ Flash 2, ASUS Auto Tuning, ASUS AI Charger+, ASUS AI Suite III, ASUS HomeCloud, ASUS Turbo App
30.5 cm
24.4 cm
