Asus X99-DELUXE/U3.1 S2011 Intel X99 DDR4 USB3.1 Bundled ATX
Quicklinx: B62GWS00 Mfr#: X99-DELUXE/U3.1
  • IEEE 802.11n
  • Bluetooth 4.0
Fully loaded for unmatched performance, with 3x3 802.11ac Wi-Fi, ultra-fast USB 3.1 Type-A Card (Dual), and Fan Extension Card for your extreme X99 build.
  • Easy-fit 10Gb/s USB 3.1 Type-A Card (Dual) bundled
  • Patent Pending OC Socket - Drive CPU and DDR4 performance beyond all expectations!
  • 5-Way Optimization by Dual Intelligent Processors 5 - One click overclock and cooling, done!
  • 3x3(3T3R) 802.11ac Wi-Fi - Fastest onboard Wi-Fi up to 1300Mb/s
  • Fan Extension Card - Powerful cooling with flexible installation & detailed control
  • Dual 32Gb/s ultrafast M.2 x4 (onboard and PCIE add-in card)
ASUS X99-DELUXE/U3.1 - motherboard - ATX - LGA2011-v3 Socket - X99 - with ASUS USB 3.1 Type-A CARD
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7, Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
Max RAM Size
64 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 2 x SATA Express port, 1 x M.2
USB / FireWire Ports
10 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Bundled with
Motherboard - ATX - with ASUS USB 3.1 Type-A CARD
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC1150
DTS Connect, High Definition Audio, DTS UltraPC II
LAN
Network Controller
Intel I211-AT / I218V
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 5 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode; quad: x16, x8, x8, x8 mode; quint: x8 mode) , 1 x PCIe 2.0 x4
Storage Interfaces
SATA-600 -connectors: 8 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 1 x SATA Express port
RAID Features
Intel Smart Response Technology
2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 10 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, NVIDIA 3-way SLI Technology Support, Teaming Technology, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS 8 Phase Power Design, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), Loss-less content protection technology, ASUS DIGI+ VRM, Intel Smart Response Technology, ASUS USB 3.0 Boost technology, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Onboard Button, ASUS USB Charger+, ASUS Wi-Fi GO!, Disk Unlocker, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O, ASUS O.C. Tuner, anti-pop function, Turbo LAN, ASUS Crystal Sound 2, ASUS Fan Xpert 3, Dual Intelligent Processors 5, Dedicated Audio Hardware Zone, Intel Rapid Recovery Technology, ASUS 4 Phase DRAM Power Design, Memory O.C. Design
ASUS 3T3R Wi-Fi moving aerials, thermistor cable, M.2 X4 bracket, fan extension card
8 x Serial ATA cable , 1 x 3-way SLI bridge
Software Included
ASUS EZ Flash 2, ASUS Auto Tuning, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, ASUS HomeCloud, ASUS Turbo App, Antivirus (OEM version)
Plug and Play, ACPI 5.0
30.5 cm
24.4 cm
