X99-DELUXE II
Awaken the true performance with one click and pioneered OC socket, plus unparalleled connectivity with 3x3 802.11ac Wi-Fi
- ASUS Aura – Features controllable RGB onboard lighting and 4-pin strip header that can be synced with an ever-growing portfolio of Aura-capable ASUS hardware.
- SafeSlot – Reinvented, strengthened PCIe slot utilizes a new insert-molding process to bind the slot to fortifying metal for superior retention and shearing resistance.
- 5-Way Optimization: Fan Xpert 4 – Elevates customized cooling to new heights, with the ability to detect PWM/DC fans on all headers, utilize high-amperage fans and control water-cooling pumps in software and UEFI.
- 5-Way Optimization: Turbo Core – Employs Intel’s latest per-core overclocking, allowing you to assign applications to specific processor cores for optimum application performance.
- Next-gen connectivity — Supreme flexibility with onboard U.2 / M.2 slots that tap into 32Gbps of PCIe bandwidth, 3x3 802.11ac Wi-Fi and USB 3.1 Type-C/Thunderbolt 3.
Make your memory go faster
Drive your memory frequencies to 3333 MHz and beyond! ASUS T-topology circuit design provides a superb memory-overclocking capability to unleash the full power of DDR4 by minimizing coupling noise and signal reflection. With innovative equidistant memory channels, it delivers balanced control and powerful overclocking compatibility. ASUS works with almost every DDR4 memory vendor to ensure a great compatibility. -
One click overclock and cooling, done
One click takes care of all that complex tuning. Your PC is smart with ASUS 5-way optimization. It dynamically optimizes essential aspects of your system based on real-time use - so you get CPU performance, everyday energy savings, stable digital power, cool and quiet fans and now even networking and audio settings that are tailored for the apps that you are using. In short, 5-way optimization ensures that your PC is perfect for gaming, entertainment, productivity or just about anything else! -
Flexible cooling controls for air and liquid
The ASUS X99 motherboards feature enhanced cooling capability to date, controllable from both Fan Xpert 4 and UEFI. -
Media-acclaimed UEFI BIOS
The smooth and slick mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced Modes help you find your way, quickly and easily. -
AURA lighting control
A well-tuned enthusiast system deserves a matching aesthetic. ASUS Aura offers full RGB control with a variety of functional presets for both built-in RGB LEDs. -
Protect your graphics card investment
SafeSlot is the PCIe slot reinvented by ASUS and engineered to provide superior retention and shearing resistance. Manufactured in a single step using an injection-molding process that integrates the slot with the fortifying metal for an inherently stronger slot, which is then firmly anchored to the PCB through additional solder points. -
More throughput, less CPU usage and great gaming experiences
X99-E features the Intel Ethernet for faster, smoother gaming. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay!
- ASUS X99-DELUXE II - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition, Core i7
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2, 2 x U.2 port
- USB / FireWire Ports
- 1 x USB-C + 3 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3333 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC1150
- DTS Connect, High Definition Audio, DTS Studio Sound
LAN
- Network Controller
- Intel I211-AT / I218V
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode; quad: x8, x8, x8, x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 1 x M.2, 2 x U.2 , SATA-600 -connectors: 4 x 7pin Serial ATA
- RAID Features
- Intel Smart Response Technology
- 2 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 3 x USB 3.1 , 1 x USB-C
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x SPDIF out - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, NVIDIA 3-way SLI Technology Support, Teaming Technology, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Smart Response Technology, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS Wi-Fi GO!, DirectKey, ASUS Enhanced DRAM Overcurrent Protection, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, Turbo LAN, Dual Intelligent Processors 5, LANGuard, Memory O.C. Design, ASUS OC Socket, USB 3.1 Boost, ASUS Overvoltage Protection, ASUS Crystal Sound 3, ASUS 5X Protection II, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot, Intel Turbo Boost Technology 3.0
- Included Accessories
- I/O back plate, 1 x M.2 screw, ASUS 3T3R Wi-Fi moving aerials, thermistor cable, M.2 X4 bracket, fan extension card, Hyper M.2 x4 Mini card, ASUS ThunderboltEX 3 card
- Cables Included
- 8 x Serial ATA cable , 1 x 3-way SLI bridge
- Software Included
- Drivers & Utilities, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, ASUS Turbo App, Antivirus (OEM version), Mobo Connect, PC Cleaner, Media Streamer, HyStream, ASUS EZ Flash 3
- 30.5 cm
- 24.4 cm
