Asus X99-DELUXE II Intel X99 S2011-V3 DDR4 U.2 M.2 USB3.1 ATX
Quicklinx: C3JNWS00 Mfr#: X99-DELUXE II
  • Bluetooth 4.0
  • IEEE 802.11n
X99-DELUXE II
Awaken the true performance with one click and pioneered OC socket, plus unparalleled connectivity with 3x3 802.11ac Wi-Fi
  • ASUS Aura – Features controllable RGB onboard lighting and 4-pin strip header that can be synced with an ever-growing portfolio of Aura-capable ASUS hardware.
  • SafeSlot – Reinvented, strengthened PCIe slot utilizes a new insert-molding process to bind the slot to fortifying metal for superior retention and shearing resistance.
  • 5-Way Optimization: Fan Xpert 4 – Elevates customized cooling to new heights, with the ability to detect PWM/DC fans on all headers, utilize high-amperage fans and control water-cooling pumps in software and UEFI.
  • 5-Way Optimization: Turbo Core – Employs Intel’s latest per-core overclocking, allowing you to assign applications to specific processor cores for optimum application performance.
  • Next-gen connectivity — Supreme flexibility with onboard U.2 / M.2 slots that tap into 32Gbps of PCIe bandwidth, 3x3 802.11ac Wi-Fi and USB 3.1 Type-C/Thunderbolt 3.
  • Make your memory go faster
    Drive your memory frequencies to 3333 MHz and beyond! ASUS T-topology circuit design provides a superb memory-overclocking capability to unleash the full power of DDR4 by minimizing coupling noise and signal reflection. With innovative equidistant memory channels, it delivers balanced control and powerful overclocking compatibility. ASUS works with almost every DDR4 memory vendor to ensure a great compatibility.
  • One click overclock and cooling, done
    One click takes care of all that complex tuning. Your PC is smart with ASUS 5-way optimization. It dynamically optimizes essential aspects of your system based on real-time use - so you get CPU performance, everyday energy savings, stable digital power, cool and quiet fans and now even networking and audio settings that are tailored for the apps that you are using. In short, 5-way optimization ensures that your PC is perfect for gaming, entertainment, productivity or just about anything else!
  • Flexible cooling controls for air and liquid
    The ASUS X99 motherboards feature enhanced cooling capability to date, controllable from both Fan Xpert 4 and UEFI.
  • Media-acclaimed UEFI BIOS
    The smooth and slick mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced Modes help you find your way, quickly and easily.
  • AURA lighting control
    A well-tuned enthusiast system deserves a matching aesthetic. ASUS Aura offers full RGB control with a variety of functional presets for both built-in RGB LEDs.
  • Protect your graphics card investment
    SafeSlot is the PCIe slot reinvented by ASUS and engineered to provide superior retention and shearing resistance. Manufactured in a single step using an injection-molding process that integrates the slot with the fortifying metal for an inherently stronger slot, which is then firmly anchored to the PCB through additional solder points.
  • More throughput, less CPU usage and great gaming experiences
    X99-E features the Intel Ethernet for faster, smoother gaming. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay!
ASUS X99-DELUXE II - motherboard - ATX - LGA2011-v3 Socket - X99
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7 Extreme Edition, Core i7
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2, 2 x U.2 port
USB / FireWire Ports
1 x USB-C + 3 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3333 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC1150
DTS Connect, High Definition Audio, DTS Studio Sound
LAN
Network Controller
Intel I211-AT / I218V
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode; quad: x8, x8, x8, x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 4 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 1 x M.2, 2 x U.2 , SATA-600 -connectors: 4 x 7pin Serial ATA
RAID Features
Intel Smart Response Technology
2 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 3 x USB 3.1 , 1 x USB-C
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x SPDIF out - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, NVIDIA 3-way SLI Technology Support, Teaming Technology, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Smart Response Technology, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS Wi-Fi GO!, DirectKey, ASUS Enhanced DRAM Overcurrent Protection, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, Turbo LAN, Dual Intelligent Processors 5, LANGuard, Memory O.C. Design, ASUS OC Socket, USB 3.1 Boost, ASUS Overvoltage Protection, ASUS Crystal Sound 3, ASUS 5X Protection II, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot, Intel Turbo Boost Technology 3.0
I/O back plate, 1 x M.2 screw, ASUS 3T3R Wi-Fi moving aerials, thermistor cable, M.2 X4 bracket, fan extension card, Hyper M.2 x4 Mini card, ASUS ThunderboltEX 3 card
8 x Serial ATA cable , 1 x 3-way SLI bridge
Software Included
Drivers & Utilities, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, ASUS Turbo App, Antivirus (OEM version), Mobo Connect, PC Cleaner, Media Streamer, HyStream, ASUS EZ Flash 3
30.5 cm
24.4 cm
