Unmatched performance and ultra-fast USB 3.1 onboard for your X99 build.
- Ultra-fast 10Gb/s USB 3.1 built in to the board
- Patent Pending OC Socket - Drive CPU and DDR4 performance beyond all expectations!
- 5-Way Optimization by Dual Intelligent Processors 5 - One click overclock and cooling, done!
- 32Gb/s ultrafast M.2 x4
- Crystal Sound 2 - Flawless audio that makes you part of the game!
- Total control anytime, anywhere with Remote GO!"
OC socket
Designed to break performance barriers, ASUS OC Socket utilizes extra pins to connect a proprietary circuit to contacts found on Haswell-E's land grid array (LGA). Combined with the customized UEFI, this exclusive feature enables higher DDR4 memory frequencies, lower latencies and enhanced stability while overclocking, extending all the way to extreme overclocking conditions, such as Liquid Nitrogen (LN2). OC Socket is 100% compatible with Haswell-E LGA 2011-v3 CPUs, ensuring the ideal combination of overclocking performance and compatibility. -
Unique cache bus voltage adjustment
Cache bus links areas such as CPU cores, DDR4 Memory Controllers, System Agent and the shared L3 Cache. It is a critical interconnect for the whole CPU subsystem. Higher cache bus frequency directly gives faster total sub-system performance. ASUS OC Socket exclusively provides an adjustable cache bus voltage to reach higher cache bus frequencies. -
Make your memory go faster
This is the first platform to support DDR4 memory and it's able to drive memory frequencies to 3200MHz (and beyond when overclocked)! ASUS-exclusive T-Topology circuit design plus OC Socket provides superb memory-overclocking capability to unleash the full power of DDR4 by minimizing coupling noise and signal reflection. With innovative equidistant memory channels, it delivers the most balanced control and powerful overclocking compatibility. ASUS works with almost every DDR4 memory vendor to ensure the best compatibility. -
Get performance, efficiency, digital power, fan control and even networking and audio tuning tailored for you
One click takes care of all that complex tuning. Your PC is smart with ASUS 5-Way Optimization. It dynamically optimizes essential aspects of your system based on real-time use - so you get superb CPU performance, everyday energy savings, ultra-stable digital power, cool and quiet fans and now even networking and audio settings that are tailored for the apps that you are using. In short, 5-Way Optimization ensures that your PC is perfect for gaming, entertainment, productivity or just about anything else! -
Fan Xpert 3
Fan Xpert 3 puts 4-pin/3-pin CPU and case fan controls in one place. It scans each fan's characteristics and delivers custom settings for each fan based on the dedicated area temperatures detected by hardware thermal sensors. Make sure every fan achieves the best balance of cooling performance and low noise. Fan Xpert 3 supports hardware-level PWM/DC combo mode for both the CPU and case fans. It even can reduce the CPU fan speed to below the default minimum, for extra-quiet and power saving operation during light loads. -
RPM Fixed Mode
Designed for users who wish to reduce noise levels to near 0dB with highly specific fan speed control. -
Auto Tuning Mode
Scans fan parameters through exclusive automatic speed detection to provide custom settings for each fan with a single click. -
Informative fan controls
Delivers complete information that allows you to take advanced control over each fan. -
Media-acclaimed UEFI BIOS
The smoothest, slickest mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced Modes help you find your way, quickly and easily. -
With the latest USB 3.1 connectivity built in and dual Type-A ports for the very fastest USB data transfers, you'll experience data-transfer speeds of up to 10Gbit/s - or twice as fast USB 3.0. The next-generation standard is completely backward-compatible with your existing USB devices, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 Boost technology automatically accelerates USB 3.1 performance even further! -
Evolve your storage speed with SATA Express
SATA Express provides up to 10Gbit/s data-transfer speeds from two PCIE 2.0 lanes, resolving the higher bandwidth request in the near future. The current SSDs consume up to 550MB/s, which is close to saturation point for SATA 6Gbit/s connections. Backwardly compatible with up to two SATA drives, SATA Express is the next-generation connectivity standard - and ensures that you and your system won't get left behind. -
Speed up with onboard M.2 up to 32Gb/s
With a 4 x PCI Express 3.0/2.0 bandwidth, M.2 supports up to 32Gb/s data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible. -
Turbo App
Gamers and professionals can get benefit from app specific optimizations by the exclusive ASUS Turbo App. Its intuitive tuning panel boosts a range of hardware; overclock your CPU, tune your fans, prioritize network data and optimize audio settings automatically. -
Crystal Sound 2
Crystal Sound 2 makes short work of optimizing audio settings for the way you want to listen, be it gaming, chatting, watching movies or relaxing to your favorite music. Onboard physical shielding, professional engineered design and premium components, including Japanese-made audio capacitors and operational amplifiers (op-amps), result in sound output that has exceptional clarity and fidelity. -
Turbo LAN
Turbo LAN with cFosSpeed traffic-shaping technology adds even more lag-reducing support and intuitive user interface. It allows you to lower lag with no expert knowledge - by up to 1.45X! If you're a tweaker, use Advanced Mode for hardcore controls. -
Intel Gigabit Ethernet - top gaming choice that goes faster with your CPU
Faster, smoother gaming - always. Intel Gigabit Ethernet has the serious double advantage of communicating directly with CPUs and offering high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay. -
Up to 2X-faster UDP game-data performance
ASUS engineers used IxChariot, an independent network-assessment test tool, to determine just how much quicker Intel Gigabit Ethernet deals with the smaller (sub-256 byte) UDP data packets that are vital for responsive gaming. The results are in - and with X99 your game-data packets flow up to two times (2X) faster than competing gaming-LAN technologies! -
Intel Core i7 Processor LGA2011-v3 ready
This motherboard supports Intel Core i7 processors in the LGA2011-v3 package, with memory and PCI Express controllers integrated to support 4-channel (8 DIMM) DDR4 memory and 40/28 PCI Express 3.0/2.0 lanes. -
Intel X99 Express Chipset
The Intel X99 Express Chipset is a single-chipset design that supports socket LGA2011-v3 Intel Core i7 processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, X99 provides a maximum 6 USB 3.0 ports, 10 SATA 6Gbit/s ports for faster data retrieval.
- ASUS X99-A/USB 3.1 - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 8 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 2 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC1150
- DTS Connect, High Definition Audio, DTS UltraPC II
LAN
- Network Controller
- Intel I218V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 8 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 2 x USB 3.1
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x SPDIF out - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- ASUS EZ Flash 2, USB BIOS Flashback, UEFI BIOS
- Hardware Features
- Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, NVIDIA 3-way SLI Technology Support, NVIDIA Quad SLI Technology Support, ASUS 8 Phase Power Design, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Smart Response Technology, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Onboard Button, ASUS USB Charger+, ASUS Remote GO!, Disk Unlocker, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, ASUS Stainless Steel Back I/O, ASUS O.C. Tuner, Turbo LAN, ASUS Crystal Sound 2, ASUS Fan Xpert 3, Dual Intelligent Processors 5, Intel Rapid Recovery Technology, ASUS 4 Phase DRAM Power Design, Memory O.C. Design, ASUS OC Socket, USB 3.1 Boost
- Included Accessories
- I/O back plate
- Cables Included
- 4 x Serial ATA cable , 1 x SLI bridge
- Software Included
- ASUS EZ Flash 2, ASUS Auto Tuning, ASUS AI Charger+, ASUS AI Suite III, ASUS HomeCloud, ASUS Turbo App
- 30.5 cm
- 24.4 cm
