Whatever you previously expected from all-rounder notebooks, forget it - because the Asus X756UA is here to change the game altogether. Well suited both to everyday working and entertainment, this Asus notebook is as versatile as it is powerful.
This Asus laptop is driven by an Intel Core i3 processor, so you can expect a sharp and slick experience. The Asus X also packs both 8GB RAM and a generous 1TB of HDD storage space.
Its USB 3.0 capability allows for lightning-quick data transfer, and it's also equipped with IceCool technology to keep palm rests cool.
Even in sleep mode, the Asus X Series is ready and raring to go - allowing you to resume your work in just a few seconds. Its Intel HD graphics card provides razor-sharp visuals whether you're immersed in gaming or watching video content. High-fidelity audio is also guaranteed thanks to Asus AudioWizard and SonicMaster technology.
Whatever you're looking for from your Asus Windows 10 notebook, the X Series delivers power and adaptability in spades.
A classic, timeless design
Designed for everyday multitasking and entertainment for smart and practical users, the ASUS X Series notebooks redefine your expectations of all-rounder notebook. With a spun-circle finish and patterned palm rests, the X Series adds a touch of sophistication and elegance to everyday computing. It houses to a large touchpad with intuitive multi-point smart gesture input, multiple USB 3.0 ports for fast data transfer and IceCool technology to keep your palm rests cool. -
Providing a smooth computing experience
Value-packed with all the essentials, the X Series reinvents your daily computing experience. Whether you are using it for work or for fun, this is an ideal machine for both productive computing and entertainment. It features an Intel Core processor and graphics card, Instant on that resumes your computer from sleep mode in seconds and USB 3.0 for 10 times faster data transfer speed. ASUS X Series gives you everything you need for a truly satisfying multitask computing and multimedia experience. -
Precise, crystal clear audio to complete the cinematic experience
On most notebooks, all sound frequencies originate from small onboard speakers. The resulting audio comes from a single source and lacks distinctiveness. Like other notebooks in the ASUS range, the X Series comes equipped with SonicMaster technology and ASUS AudioWizard to bring you high fidelity audio. Experience omnidirectional sound and hear each individual instrument's nuances with the X Series. -
Precise input
The ASUS Golden Finger team puts natural interfaces first, developing standards far beyond industry average. This assures ASUS provides the most comfortable and responsive experiences in every application and at all times. The X Series has a large touchpad equipped with Smart Gesture technology for quick and precise response across a wide range of touch inputs. The ergonomic seamless one-piece keyboard is designed to provide you the most comfortable typing experience.
- ASUS X756UA-TY006T - 17.3" - Intel Core i3 - 6100U - 8 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i3 (6th Gen) - 6100U / 2.3 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (2 x 4 GB)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 520
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 2-cell
- Glossy dark brown IMR with hairline texture (LCD cover), matte dark brown IMR with hairline texture (top)
- 41.5 cm x 27.3 cm x 3 cm
- 2.69 kg
- Environmental Standards
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i3 (6th Gen) 6100U / 2.3 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Smart Cache
- RAM
- 8 GB (2 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 1 TB HDD SATA 6Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 60% NTSC
- ASUS Splendid Video Intelligence Technology, glare
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS AudioWizard
Input
- Keyboard, touchpad
- ASUS Smart Gesture technology
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 2-cell lithium polymer
- Capacity
- 38 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , HDMI , LAN , 2 x USB 2.0 , USB 3.0 , VGA , USB-C Gen 1
- Memory Card Reader
- 2 in 1 (SD Card, MultiMediaCard)
- Security lock slot (cable lock sold separately), system password, hard drive password, ASUS IceCool design
- Included Accessories
- Power adapter
- 2.69 kg
Sustainability Information
- TCO Certified
