The ASUS X series is the perfect all-round laptop for work and play. Stylish and durable design is combined with Intel processors, while mere second Instant on gives smartphone like accessibility and SonicMaster technology gives great sound quality. Value-packed with all the essentials, the X series reinvents your daily computing experience. Whether you are using it for work or for fun, this is an ideal machine for both productive computing and entertainment. It features a powerful processor and Instant on that resumes your computer from sleep mode in seconds and USB 3.0 for faster data transfer speed. ASUS X series gives you everything you need for a truly satisfying multitask computing and multimedia experience. On most notebooks, all sound frequencies originate from small onboard speakers. The resulting audio comes from a single source and lacks distinctiveness. Like other notebooks in the ASUS range, the X series comes equipped with SonicMaster technology and ASUS AudioWizard to bring you high fidelity audio. Experience omnidirectional sound and hear each individual instrument's nuances with the X series.
A classic, timeless design
The ASUS X series is the perfect all-round laptop for work and play. Stylish and durable design is combined with Intel processor, while mere second Instant on gives smartphone like accessibility and SonicMaster technology gives great sound quality. -
Providing a smooth computing experience
Value-packed with all the essentials, the X Series reinvents your daily computing experience. Whether you are using it for work or for fun, this is an ideal machine for both productive computing and entertainment. It features a powerful processor and Instant on that resumes your computer from sleep mode in seconds and USB 3.0 faster data transfer speed. ASUS X series gives you everything you need for a truly satisfying multitask computing and multimedia experience. -
Precise, crystal clear audio to complete the cinematic experience
On most notebooks, all sound frequencies originate from small onboard speakers. The resulting audio comes from a single source and lacks distinctiveness. Like other notebooks in the ASUS range, the X series comes equipped with SonicMaster technology and ASUS AudioWizard to bring you high fidelity audio. Experience omnidirectional sound and hear each individual instrument's nuances with the X series. -
Precise input
The ASUS Golden Finger team puts natural interfaces first, developing standards far beyond industry average. This assures ASUS provides the most comfortable and responsive experiences in every application and at all times. The X series has a large touchpad equipped with Smart Gesture technology for quick and precise response across a wide range of touch inputs. The ergonomic seamless one-piece keyboard is designed to provide you the most comfortable typing experience.
- ASUS X751LAV-TY482T - 17.3" - Intel Core i3 - 5010U - 6 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i3 (5th Gen) - 5010U / 2.1 GHz / 3 MB Cache
- Memory
- 6 GB DDR3L (1 x 4 GB + 2 GB (soldered))
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 5500
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Gigabit Ethernet
- Battery
- 4-cell
- Black texture
- 41.5 cm x 27.2 cm x 3 cm
- 2.8 kg
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5010U / 2.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- RAM
- 6 GB (1 x 4 GB + 2 GB (soldered))
- Max RAM Supported
- 12 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- ASUS Splendid Video Intelligence Technology
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster Lite, ASUS AudioWizard
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-touch touchpad, ASUS Smart Gesture technology
Communications
- Wireless
- 802.11b/g/n
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell
AC Adapter
- Output
- 65 Watt, 19 V
Connections & Expansion
- Headphone/microphone combo jack , 3 x USB 3.0 , HDMI , LAN
- Memory Card Reader
- 2 in 1 (SD Card, MultiMediaCard)
Software
- Software Included
- ASUS WebStorage
- Black texture
- ASUS IceCool design
- Included Accessories
- Power adapter
- 2.8 kg
