Asus X540YA-XX020T AMD E1-7010 4GB 1TB 15.6" Windows 10
Quicklinx: CBMCWS00 Mfr#: X540YA-XX020T
  • IEEE 802.11n
Marketing description is not available.
  • Faster and easier connections with USB Type-C
    The reversible USB Type-C port makes connecting devices much easier; and gives you super-fast USB 3.1 speeds so you can transfer a movie to a USB drive in seconds. Its compact port design even helps preserve X540YA's thin dimensions.
  • Crafted speaker design for greater sound
    The X540YA features round speakers that maximize every cubic millimeter of available chassis space to give you better low frequency performance and reduced noise.
  • Elegant finished, lightweight design
    ASUS X540YA has a solid and lightweight chassis - ideal to take with you when you're out and about. Its premium brushed finish turns heads and makes sure that you stand out from the crowd.
ASUS VivoBook X540YA XX020T - 15.6" - AMD E1 - 7010 - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
AMD E1 7010 / 1.5 GHz / 1 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R2
Integrated Webcam
802.11b/g/n, 10/100 Ethernet
3-cell
Chocolate black IMR with hairline (LCD cover), gold IMR with hairline (top)
38.1 cm x 25.2 cm x 2.72 cm
2 kg
Environmental Standards
- EPEAT Climate+
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
1 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Colour Gamut
45% NTSC
ASUS Splendid Video Intelligence Technology, glare
Audio & Video
Graphics Processor
AMD Radeon R2
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard
Input
Keyboard, touchpad
ASUS Smart Gesture technology
Communications
Wireless
802.11b/g/n
Network Interface
10/100 Ethernet
3-cell Lithium Ion
33 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.0 , VGA , USB 2.0 , HDMI , LAN , USB-C Gen 1
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
System password, hard drive password, ASUS IceCool design
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
2 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
