A classic, timeless design
The ASUS X is the perfect all-round laptop for work and play. Stylish and durable design is combined with high-performing processor, while fast InstantOn gives smartphone-like accessibility and SonicMaster technology gives great sound quality. -
Providing a smooth computing experience
Value-packed with all the essentials, the X laptop reinvents your daily computing experience. Whether you are using it for work or for fun, this is an ideal machine for both productive computing and entertainment. It features powerful processor and Instant On that resumes your computer from sleep mode fast and USB 3.0 for much faster data transfer speed. ASUS X gives you everything you need for a truly satisfying multitask computing and multimedia experience. -
Precise, crystal clear audio to complete the cinematic experience
The X laptop comes equipped with SonicMaster technology to bring you high fidelity audio. Experience omnidirectional sound and hear each individual instrument's nuances with the X laptop. -
Precise input
The ASUS team puts natural interfaces first. The X laptop has a large touchpad equipped with Smart Gesture technology for quick and precise response across a wide range of touch inputs. The ergonomic seamless one-piece keyboard is designed to provide you the extremely comfortable typing experience.
- ASUS VivoBook X540SA-XX095T - 15.6" - Intel Pentium - N3700 - 4 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Pentium N3700 / 1.6 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- 802.11b/g/n, 10/100 Ethernet
- Battery
- 3-cell - up to 6 hours
- Silver gradient IMR with hairline
- 38.1 cm x 25.2 cm x 2.54 cm
- 2 kg
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 1 TB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- ASUS Splendid Video Intelligence Technology, ASUS EyeCare Technology
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS AudioWizard
Input
- Keyboard, touchpad
- ASUS Smart Gesture technology
Communications
- Wireless
- 802.11b/g/n
- Network Interface
- 10/100 Ethernet
- Technology
- 3-cell Lithium Ion
- Capacity
- 33 Wh
- Run Time
- Up to 6 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.47 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.0 , VGA , USB 2.0 , HDMI , LAN , USB-C Gen 1
- Memory Card Reader
- 3 in 1 (SD Card, SDHC Card, SDXC Card)
- System password, hard drive password, ASUS IceCool design
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- 2 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
