Asus X540LA-XX234T Intel Core i5-5200U 4GB 1TB 15.6" Windows 10
Quicklinx: CBM9WS00 Mfr#: X540LA-XX234T
  • Core i5
  • IEEE 802.11n
Marketing description is not available.
  • A classic, timeless design
    Designed for everyday multitasking and entertainment for smart and practical users, the ASUS X series notebooks redefine your expectations of all-rounder notebook. With a spun-circle finish and patterned palm rests, the X series adds a touch of sophistication and elegance to everyday computing. It houses to a large touchpad with intuitive multi-point smart gesture input, multiple USB 3.0 ports for fast data transfer and IceCool technology to keep your palm rests cool.
  • Providing a smooth computing experience
    Value-packed with all the essentials, the X series reinvents your daily computing experience. Whether you are using it for work or for fun, this is an ideal machine for both productive computing and entertainment. It features an Intel Core processor and graphics card, Instant on that resumes your computer from sleep mode in seconds and USB 3.0 for 10 times faster data transfer speed. ASUS X series gives you everything you need for a truly satisfying multitask computing and multimedia experience.
  • Precise, crystal clear audio to complete the cinematic experience
    On most notebooks, all sound frequencies originate from small onboard speakers. The resulting audio comes from a single source and lacks distinctiveness. Like other notebooks in the ASUS range, the X series comes equipped with SonicMaster technology and ASUS AudioWizard to bring you high fidelity audio. Experience omnidirectional sound and hear each individual instrument's nuances with the X series.
  • Precise input
    The ASUS Golden Finger team puts natural interfaces first, developing standards far beyond industry average. This assures ASUS provides the most comfortable and responsive experiences in every application and at all times. The X series has a large touchpad equipped with Smart Gesture technology for quick and precise response across a wide range of touch inputs. The ergonomic seamless one-piece keyboard is designed to provide you the most comfortable typing experience.
ASUS VivoBook X540LA-XX234T - 15.6" - Intel Core i5 - 5200U - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i5 (5th Gen) - 5200U
4 GB DDR3L
Storage
1 TB HDD
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Integrated Webcam
802.11b/g/n, 10/100 Ethernet
3-cell
38.14 cm x 25.15 cm x 2.72 cm
2 kg
Environmental Standards
- EPEAT Climate+
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (5th Gen) 5200U
Number of Cores
Dual-Core
64-bit Computing
RAM
4 GB
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
1 TB HDD
Optical Drive
DVD±RW (±R DL)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
ASUS Splendid Video Intelligence Technology
Audio & Video
Graphics Processor
Camera
Yes - VGA
Image Sensor Type
CMOS
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard
Input
Keyboard, touchpad
ASUS Smart Gesture technology
Communications
Wireless
802.11b/g/n
Network Interface
10/100 Ethernet
3-cell
33 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.47 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.0 , VGA , USB 2.0 , HDMI , LAN , USB-C Gen 1
Memory Card Reader
3 in 1 (SD Card, SDHC Card, SDXC Card)
System password, hard drive password, ASUS IceCool design
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
2 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
