Brand
Asus W202NA GJ0022RA N3350 4GB 32GB 11.6" Chrome
Quicklinx: GBCHWS00 Mfr#: W202NA-GJ0022RA
Display Size: 11.6in
Processor Model: N3350
Operating System: Windows 10 Pro National Academic
Hard Drive Capacity: 64GB
Optical Storage: None
  • Celeron
  • IEEE 802.11n
More than 50 in stock
£125.00 ex VAT
£150.00 inc VAT
Designed for teachers and students, the VivoBook W202NA features an ergonomically designed keyboard, along with rubber-reinforced edges and corners to protect the laptop against bumps and knocks.
  • Designed to work in or out of the classroom
    The VivoBook W202NA features rubber-reinforced edges and corners designed to reduce the impact of knocks and bumps to protect critical internal components. The 180° rotatable hinge lets the user tilt the display at a comfortable viewing angle. The VivoBook W202NA has backpack-friendly dimensions with a slim profile and a desktop footprint smaller than an A4 sheet.
  • Easy system maintenance
    The VivoBook W202NA has a unique three-piece modular design for easy access to internal components. This makes it incredibly easy for IT staff to service or upgrade parts without having to remove other components. It also significantly reduces downtime with key components, such as the keyboard, touchpad, battery, motherboard, power jack daughter board, and display panels, which are all easily accessible in a minimum amount of steps.
ASUS W202NA GJ0022RA - 11.6" - Celeron N3350 - 4 GB RAM - 64 GB eMMC
Notebook - 180-degree hinch design
Operating System
Intel Celeron N3350 / 1.1 GHz (2.4 GHz) / 2 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
64 GB eMMC
Optical Drive
No optical drive
Display
11.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 500
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip
Dark blue
29.4 cm x 20 cm x 2.25 cm
1.2 kg
Environmental Standards
ENERGY STAR Qualified
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
2 MB
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Storage
Main Storage
64 GB SSD eMMC
Display
11.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
200 cd/m²
Anti-glare, 45% NTSC colour gamut
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, array microphone
Audio Features
ASUS Bang & Olufsen ICEpower
Input
Keyboard, touchpad
Spill-resistant, chiclet keyboard
Communications
Wireless
2-cell Lithium Ion
38 Wh
AC Adapter
Input
Output
33 Watt, 19 V, 1.75 A
Connections & Expansion
HDMI , 2 x USB 3.2 Gen 1 , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Dark blue
Case Material
Plastic
Security
System password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
UL, CB, FCC, RoHS, WEEE, ErP 2013
1.2 kg
ENERGY STAR Certified
Graphics: Intel HD Graphics 500
Hard Drive Type: SSD
Brand: Asus
Stock Status: In stock
