Asus VX279Q 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
SUPERIOR IMAGE QUALITY MEETS CLASSIC ELEGANT DESIGN
Quicklinx: 9TNQWS00 Mfr#: VX279Q
Inspired by millennia of artistic legacy, the VX279Q sports an elegant and precision-crafted sundial design. The VX279Q features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals.
VX279Q features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology - delivering improved color accuracy plus increased energy efficiency.
With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250 cd/m2 brightness, VX279Q augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals.
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness.
ASUS includes its exclusive QuickFit virtual scale feature with the VX279Q, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
  • Superior image quality meets frameless elegant design
  • Vivid, lifelike visuals
  • 80,000,000:1 ASUS smart contrast ratio
  • Splendid Video Intelligence technology
  • QuickFit virtual scale for true what you see is what you get
ASUS VX279Q - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
AC 120/230 V (50 - 60 Hz)
62.26 cm x 21.01 cm x 44.13 cm
4.6 kg
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, GOST-R, ErP Ready, CEL
Display Type
Energy Class
Class A+
29 kWh
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology
62.26 cm x 21.01 cm x 44.13 cm - with stand
4.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
HDMI , VGA , Audio line-in , Headphones , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+20
1 x audio cable , 1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
20 W
Power Consumption (Typical)
46 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
