Inspired by millennia of artistic legacy, VX279H sports an elegant and precision-crafted sundial design. The VX279H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. It's ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offers extensive connectivity options.
Extensive connectivity and built-in stereo speaker for multimedia enjoyment
VX279H comes with rich connectivity including dual HDMI/MHL ports and D-sub so that users could easily share MHL mobile devices content on a much bigger screen as well as charging MHL devices simultaneously. Also connect VX279H with Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers. -
Vivid, lifelike visuals
VX279H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology - delivering improved color accuracy plus increased energy efficiency. -
ASUS smart contrast ratio
With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250cd/m² brightness, VX279H augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals. -
ASUS-exclusive VividPixel technology
The VividPixel Technology enhances outline, sharpness, and color saturation of images and videos to deliver high-quality visual experience. -
Splendid video intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey. To deliver a more comfortable viewing experience, ASUS Eyecare monitors adopts Flicker-Free Technology to clear out the distracted flicker shown on the screen and help reduce eye fatigue for long-period watching.
- ASUS VX279H-W - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 23 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50 - 60 Hz)
- White
- 62.26 cm x 21.01 cm x 44.13 cm
- 4.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL level 1
- Display Type
- Energy Class
- Class A+
- 33 kWh
- Diagonal Size
- 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, colour temperature
- HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, Slim Design
- White
- 62.26 cm x 21.01 cm x 44.13 cm - with stand
- 4.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
- 2 x MHL / HDMI , VGA , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x audio cable , 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- 23 W
- Power Consumption (Typical)
- 29.1 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
