Inspired by millennia of artistic legacy, the VX279H sports an elegant and precision-crafted sundial design. The VX279H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. Its ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offers extensive connectivity options.
VX279H features rich connectivity including dual HDMI/MHL ports and D-sub so that users could easily share MHL mobile devices content on a much bigger screen as well as charging MHL devices simultaneously. Also connect VX279H with Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers. The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness.
Superior image quality meets frameless elegant design
Inspired by millennia of artistic legacy, the VX279H sports an elegant and precision-crafted sundial design. The VX279H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. Its ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offers extensive connectivity options. -
Extensive connectivity and built-in stereo speaker for multimedia enjoyment
VX279H features rich connectivity including dual HDMI/MHL ports and D-sub so that users could easily share MHL mobile devices content on a much bigger screen as well as charging MHL devices simultaneously. Also connect VX279H with Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers. -
Wide-view angles
VX279H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology - delivering improved color accuracy plus increased energy efficiency. -
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. -
QuickFit Virtual Scale for true what you see is what you get
ASUS includes its exclusive QuickFit Virtual Scale feature with the VX279H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
- ASUS VX279H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 22.6 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xMHL, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Black
- 62.26 cm x 21.01 cm x 44.13 cm
- 4.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL level 1
- Display Type
- Energy Class
- Class A+
- 33 kWh
- Diagonal Size
- 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, colour temperature
- HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, Slim Design
- Black
- 62.26 cm x 21.01 cm x 44.13 cm - with stand
- 4.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
- 2 x MHL / HDMI , VGA , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x audio cable , 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- 22.6 W
- Power Consumption (Typical)
- 29.1 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
