Product
Asus VX278Q 27" 1920x1080 1ms VGA HDMI DP LED Gaming Monitor
Quicklinx: BJWHWS00 Mfr#: VX278Q
Delicate touches make a monitor truly great, VX278Q Full HD LED monitor, with extremely quick 1 ms response time, 80,000,000:1 high contrast ratio is optimized for the finest image and color quality. This approach extends to the sturdy sundial-inspired design stand and ultra-slim profile without compromising style in ensuring stability and durability.
  • 80,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Full HD 1080p support
    Enter a spectacular world of colors with Full HD 1080p support.
  • 1ms response time
    Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback.
  • Aspect control function
    Aspect control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Robust connectivity for multimedia enjoyment
    VX278H comes with rich connectivity including dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment.
  • ASUS flicker free technology
    ASUS flicker-free technology by using smart dynamic backlight adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, brings comfort viewing experience to avoid computer vision syndrome.
ASUS VX278Q - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
64.07 cm x 21.01 cm x 45.166 cm
4.5 kg
Environmental Standards
ENERGY STAR Qualified
UL, BSMI, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, MEPS, ErP Ready, TCO Displays 6.0, EAC
3 years warranty
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select
ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, Blue Light Filter technology
64.07 cm x 21.01 cm x 45.166 cm - with stand
4.5 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
HDMI , VGA , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable
Security Slot Type
Kensington security slot
AC 120/230 V (50 - 60 Hz)
29.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 64.07 cm - depth: 4.197 cm - height: 38.13 cm , With stand - width: 64.07 cm - depth: 21.01 cm - height: 45.166 cm - weight: 4.5 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
BJWH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BJWH C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.46
BJWH C2G 5m Select High Speed HDMI with Ethernet In Stock £21.69
BJWH C2G 10m Select High Speed HDMI with Ethernet In Stock £41.46
BJWH C2G Pro HDMI to VGA Converter In Stock £51.78
BJWH C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
