Delicate touches make a monitor truly great, VX278H Full HD LED monitor, with extremely quick 1 ms response time, 80,000,000:1 high contrast ratio and HDMI interfaces, is optimized for the finest image and color quality. This approach extends to the sturdy sundial-inspired design stand and ultra-slim profile without compromising style in ensuring stability and durability.
80,000,000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
Full HD 1080p support
Enter a spectacular world of colors with Full HD 1080p support. -
1ms response time
Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback. -
Aspect control function
Aspect control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
Robust connectivity for multimedia enjoyment
VX278H comes with rich connectivity including dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment. -
ASUS flicker free technology
ASUS flicker-free technology by using smart dynamic backlight adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, brings comfort viewing experience to avoid computer vision syndrome.
- ASUS VX278H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 44 kWh
- Power Consumption (On mode)
- 30 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.07 cm x 21.01 cm x 45.166 cm
- Environmental Standards
- ENERGY STAR Qualified
- UL, BSMI, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, ErP Ready, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 44 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, aspect control
- ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Slim Design, Low Blue Light Mode, Flicker Free technology, Mercury free, Blue Light Filter technology, 72% NTSC colour gamut
- Black
- 64.07 cm x 21.01 cm x 45.166 cm - with stand
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- 2 x HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 30 W
- Power Consumption (Typical)
- 29.1 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 64.07 cm - depth: 21.01 cm - height: 45.166 cm , Without stand - width: 64.07 cm - depth: 4.197 cm - height: 38.13 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
