Asus VX278H 27" 1920x1080 1ms DVI HDMI LED Gaming Monitor
Quicklinx: BJWGWS00 Mfr#: VX278H
Delicate touches make a monitor truly great, VX278H Full HD LED monitor, with extremely quick 1 ms response time, 80,000,000:1 high contrast ratio and HDMI interfaces, is optimized for the finest image and color quality. This approach extends to the sturdy sundial-inspired design stand and ultra-slim profile without compromising style in ensuring stability and durability.
  • 80,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Full HD 1080p support
    Enter a spectacular world of colors with Full HD 1080p support.
  • 1ms response time
    Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback.
  • Aspect control function
    Aspect control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Robust connectivity for multimedia enjoyment
    VX278H comes with rich connectivity including dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment.
  • ASUS flicker free technology
    ASUS flicker-free technology by using smart dynamic backlight adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, brings comfort viewing experience to avoid computer vision syndrome.
ASUS VX278H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
64.07 cm x 21.01 cm x 45.166 cm
Environmental Standards
ENERGY STAR Qualified
UL, BSMI, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, ErP Ready, EAC
3-year warranty
Display Type
Energy Class
Class A
44 kWh
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, aspect control
ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Slim Design, Low Blue Light Mode, Flicker Free technology, Mercury free, Blue Light Filter technology, 72% NTSC colour gamut
64.07 cm x 21.01 cm x 45.166 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
2 x HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
30 W
Power Consumption (Typical)
29.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 64.07 cm - depth: 21.01 cm - height: 45.166 cm , Without stand - width: 64.07 cm - depth: 4.197 cm - height: 38.13 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
BJWG C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
