Asus VX24AH 23.8" 2560x1440 5ms VGA HDMI IPS Monitor
Quicklinx: BJWMWS00 Mfr#: VX24AH
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
£173.61 ex VAT
£208.33 inc VAT
Envision bigger with WQHD! Premium wide-format VX24AH LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive SplendidPlus Video Intelligence technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true "what you imagine is what you create" power. Dual HDMI support WQHD natively, accentuated by room-dominating audio via twin speakers.
  • See better and wider
    The VX24AH WQHD monitor provides high quality visuals. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays.
  • Made for work and play
    The ASUS VX24AH provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy more desktop space to spread out your windows and palettes. It is also sharper, delivering ultra-smooth visuals thanks to quick response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color.
  • Extensive connectivity
    The VX24AH features a host of connectivity options. The HDMI port supports MHL which allows you to use the MHL with HDMI connection to view content from your mobile device on the VX24AH while simultaneously charging the mobile device. Twin built-in speakers provide quality audio for a completely immersive home theater experience.
  • QuickFit Virtual Scale for true what you see is what you get
    ASUS includes its exclusive QuickFit Virtual Scale feature with the VX24AH, allowing you to preview photos and documents on-screen in their actual size prior to printing.
  • ASUS SplendidPlus Video Intelligence technology
    ASUS SplendidPlus Video Intelligence technology is built upon a color engine that provides preset modes that allow you to adjust your display accordingly to ensure color accuracy and image fidelity to give you colors that best suit what's showing on the screen.
  • ASUS EyeCare technology
    The VX24AH is also equipped with the ASUS EyeCare technology. It adopts flicker-free technology which clears out the distracted flicker shown on the screen and delivers a more comfortable viewing experience.
  • ASUS VividPixel technology
    ASUS VividPixel technology adds to the VX24AH crystal-clear and detailed visuals by enhancing image outlines and reducing noise bars.
ASUS VX24AH - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.206 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
54.05 cm x 21.01 cm x 39.44 cm
3.5 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, J-MOSS, ErP Ready, ISO9241-307
3-year warranty
Display Type
Energy Class
Class A
36 kWh
25 W
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.206 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature
HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), 100% sRGB colour gamut, ASUS GamePlus, ASUS VividPixel Technology, Slim Design, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
54.05 cm x 21.01 cm x 39.44 cm - with stand
3.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
2 x HDMI , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
1 x audio cable , 1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
External
65 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 54.05 cm - depth: 21.01 cm - height: 39.44 cm - weight: 3.5 kg , Without stand - width: 54.05 cm - depth: 4.02 cm - height: 32.63 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus VX24AH 23.8 Bundle deal on Asus VX24AH 23.8" 2560x1440 5ms VGA HDMI IPS Monitor
£272.78
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 150 - 300
