Asus VX207NE 19.5" 1366x768 5ms D-Sub DVI VGA Black Monitor
Quicklinx: C1V3WS00 Mfr#: VX207NE
VX207NE monitor with extremely quick 5ms response time, 100,000,000:1 high contrast ratio is optimized for the finest quality. This approach extends to the sturdy sundial-inspired design stand and ultra-slim profile without compromising style in ensuring stability and durability.
  • Eye-care features with ultra-slim elegant design
    VX207NE LED monitor, with 100,000,000:1 high contrast ratio is optimized for the finest quality. Your eyes are drawn to its unprecedented design - a fusion between the sundial-inspired design stand and ultra-slime profile without compromising style in ensuring stability and durability.
  • True-to-life pictures powered by LED
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • 5ms response time
    Quick response time of 5ms (GTG) eliminates ghosting and tracers for more fluid video playback.
  • Aspect Control function
    Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • SplendidPlus Video Intelligence technology
    The exclusive SplendidPlus Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 8 preset video modes (Reading, Darkroom, Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
  • Reading mode
    Creating comfortable experience as if reading actual books by adjusting the monitor's color temperature and brightness levels, simulating paperback books.
  • Darkroom mode
    Darkroom mode is the best choice for soft ambient light environment for visual pleasure.
  • QuickFit virtual scale
    The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
ASUS VX207NE - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Native Resolution
1366 x 768
Pixel Pitch
0.311 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
46.69 cm x 18.996 cm x 34.92 cm
2.3 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, MEPS, J-MOSS, ErP Ready
3-year warranty
Display Type
Diagonal Size
19.5"
Panel Type
TN
Native Resolution
1366 x 768
Pixel Pitch
0.311 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, aspect control
sRGB colour management, ASUS Splendid Video Intelligence Technology, ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale
46.69 cm x 18.996 cm x 34.92 cm - with stand
2.3 kg
DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
External
Input Voltage
Power Consumption (Typical)
13.96 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 46.69 cm - depth: 18.996 cm - height: 34.92 cm - weight: 2.3 kg , Without stand - width: 46.69 cm - depth: 3.69 cm - height: 27.68 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
