VX207NE monitor with extremely quick 5ms response time, 100,000,000:1 high contrast ratio is optimized for the finest quality. This approach extends to the sturdy sundial-inspired design stand and ultra-slim profile without compromising style in ensuring stability and durability.
Eye-care features with ultra-slim elegant design
VX207NE LED monitor, with 100,000,000:1 high contrast ratio is optimized for the finest quality. Your eyes are drawn to its unprecedented design - a fusion between the sundial-inspired design stand and ultra-slime profile without compromising style in ensuring stability and durability. -
True-to-life pictures powered by LED
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
5ms response time
Quick response time of 5ms (GTG) eliminates ghosting and tracers for more fluid video playback. -
Aspect Control function
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
SplendidPlus Video Intelligence technology
The exclusive SplendidPlus Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 8 preset video modes (Reading, Darkroom, Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey. -
Reading mode
Creating comfortable experience as if reading actual books by adjusting the monitor's color temperature and brightness levels, simulating paperback books. -
Darkroom mode
Darkroom mode is the best choice for soft ambient light environment for visual pleasure. -
QuickFit virtual scale
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
- ASUS VX207NE - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Panel Type
- TN
- Native Resolution
- 1366 x 768
- Pixel Pitch
- 0.311 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 46.69 cm x 18.996 cm x 34.92 cm
- 2.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, MEPS, J-MOSS, ErP Ready
- 3-year warranty
- Display Type
- Diagonal Size
- 19.5"
- Panel Type
- TN
- Native Resolution
- 1366 x 768
- Pixel Pitch
- 0.311 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, aspect control
- sRGB colour management, ASUS Splendid Video Intelligence Technology, ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale
- Black
- 46.69 cm x 18.996 cm x 34.92 cm - with stand
- 2.3 kg
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 13.96 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 46.69 cm - depth: 18.996 cm - height: 34.92 cm - weight: 2.3 kg , Without stand - width: 46.69 cm - depth: 3.69 cm - height: 27.68 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
