Asus VW24ATLR 24" 1920x1080 5ms DVI VGA LED Monitor
Quicklinx: 9TR4WS00 Mfr#: VW24ATLR
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£154.76 ex VAT
£185.71 inc VAT
The human sensor feature provides convenience with energy savings and information security by ensuring that the monitor conserves power when it is not in use. The sensor prompts the monitor to switch to power saving mode when it detects the user is away from the monitor, and then resume normal operation when the user returns.
The ergonomically-designed VW24ATLR monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
  • Energy saving and information security with built-in human sensor
  • 100,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • QuickFit virtual scale function
    What you see is what you get. Allowing users to preview photos on screen in their actual sizes prior to printing. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
  • Versatile comfort with ergonomic design
ASUS VW24ATLR - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22.4 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare
56.84 cm x 22.48 cm x 37.88 cm
5.7 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, J-MOSS, ErP Ready
3-year warranty
Display Type
Energy Class
Class A
33 kWh
22.4 W
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, ASUS QuickFit Virtual Scale, Human Sensor
56.84 cm x 22.48 cm x 37.88 cm - with stand
5.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D , Audio line-in , VGA
Mechanical
Tilt Angle
-5/+22
Swivel Angle
320
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
Internal
23.2 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
Without stand - width: 56.84 cm - depth: 6.15 cm - height: 34.68 cm
ENERGY STAR Certified
Limited warranty - 3 years
Asus VW24ATLR 24 Bundle deal on Asus VW24ATLR 24" 1920x1080 5ms DVI VGA LED Monitor
£253.93
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 150 - 300
