The human sensor feature provides convenience with energy savings and information security by ensuring that the monitor conserves power when it is not in use. The sensor prompts the monitor to switch to power saving mode when it detects the user is away from the monitor, and then resume normal operation when the user returns.
The ergonomically-designed VW24ATLR monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
Energy saving and information security with built-in human sensor
The human sensor feature provides convenience with energy savings and information security by ensuring that the monitor conserves power when it is not in use. The sensor prompts the monitor to switch to power saving mode when it detects the user is away from the monitor, and then resume normal operation when the user returns. -
100,000,000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
QuickFit virtual scale function
What you see is what you get. Allowing users to preview photos on screen in their actual sizes prior to printing. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. -
Versatile comfort with ergonomic design
- ASUS VW24ATLR - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 22.4 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.84 cm x 22.48 cm x 37.88 cm
- 5.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, J-MOSS, ErP Ready
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 33 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Human Sensor, 72% NTSC colour gamut
- Black
- 56.84 cm x 22.48 cm x 37.88 cm - with stand
- 5.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- DVI-D , Audio line-in , VGA
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 22.4 W
- Power Consumption (Typical)
- 23.2 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 56.84 cm - depth: 6.15 cm - height: 34.68 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
