The Republic of Gamers is committed to helping you win more through superior audio power, precise positioning, and lifelike immersion - the perfect aids for those critical online shooter moments. Opposing snipers hide in the dark, taking advantage of cover to keep you suppressed? It's time to get your team on the offensive with powerful and precise battleground audio intelligence - thanks to advanced Xonar sound hardware. No more confusion or uncertainty. Clear audio turns you into a virtual online gaming general, and paves the way to victory.
Superior audio detection and positioning make gamers equipped with ROG audio gear true champions. Developed using real life insight from full-time players and refined by the expertise of the Xonar team, the ultimate goal here is to help you win! Built for the most dedicated gamers, ROG audio product is committed to win-boosting features, from clear communications to precision detection that amplifies every footstep taken by opponents. No more sneaking around or getting stealth-flanked!
Focus to win
Retaining advanced active noise cancellation technology specifically designed to eliminate low frequency computer fan noise, high frequency environmental noise, and human voice from external sources, the ROG team researched and created Vulcan PRO with the exclusive ROG Spitfire USB audio processor. It allows gamers to experience precise audio positioning and enhanced surround with no driver install needed, perfect for LAN parties. -
ROG Spitfire USB audio processor - powerful driver-free hardware DSP
ROG Vulcan PRO adds the ROG Spitfire USB audio processor, which works at the hardware level and requires no driver install. Its design contributes to quicker setup in gaming events, and complies with the most professional venues, which prohibit the installation of additional drivers. The ROG Spitfire deploys the powerful hardware digital signal processor to offer such driver-free convenience, especially perfect for LAN parties. -
Block disruption perfectly with advanced dual noise technologies
Noise ranks as one of the leading issues for pro gamers, often causing distractions and leading to the wrong decisions - which in turn lower win ratios. The ROG Vulcan PRO features brushed metal headphone side covers that offer a style as well as better strength. It offers gamers active and passive noise cancellation technologies, meticulously designed by ROG engineers to ensure better gaming success and immersion. -
Long-lasting comfort and gamer-friendly design
ROG Vulcan PRO employs a durable and detachable braided cable, enabling easy wire management and eliminating unsightly entanglements. It uses emergency detachment, unplugging neatly and safely if you stand up suddenly while gaming with the headset on, preventing the unexpected pull from sending your precious hardware tumbling to the floor.
- ASUS Vulcan PRO Republic of Gamers - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Additional Functions
- Amplifier
- Headphones Form Factor
- Full size binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- 7.1 Channel Virtual Surround Sound
- Audio Specifications
- Frequency Response 10 - 20000 Hz - Sensitivity 42 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone
- Detachable - boom
- 2-year warranty
- Product Type
- Headset - wired
- Amplifier
- 21 cm
- 7 cm
- 18 cm
- 326 g
- Recommended Use
- Computer
Audio Output
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- 10 - 20000 Hz
- Total Harmonic Distortion (THD)
- 0.01%
- Sensitivity
- 42 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium magnet
- In-Cord Volume Control
Microphone
- Boom
- Sensitivity
- 42 dB
- 100 - 10000 Hz
- Connector Type
- Headphones (mini-phone 3.5mm) , Microphone (mini-phone 3.5mm)
- Included Accessories
- Carrying case
- Cable Details
- Headset cable - 2.5 m
- Limited warranty - 2 years
