Experience stunning visuals on this great touchscreen display with ASUS Smart Contrast Ratio and fast response time. Simply tap, drag, pinch, zoom or spin with your fingers for an amazingly natural and effortless touch experience.
An incredibly intuitive touch experience
The ASUS VT207N touchscreen monitor combines multi-touch capability with great image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display allows you to work smarter and more efficiently. -
Stunningly vivid display
The ASUS VT207N has a 19.5-inch widescreen display that delivers outstanding image quality thanks to its HD 1600 x 900 resolution and ASUS Smart Contrast Ratio (ASCR). With a fast response time, you'll get pin-sharp images for any kind of content. And you can also choose your preferred aspect ratio for scaling non-widescreen images via the aspect ratio control. -
The touchscreen monitor that gives you much more
ASUS QuickFit Virtual Scale's onscreen alignment grid overlay helps you align and preview actual-size photos and documents on screen prior to printing, making sure they print perfectly every time. ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the great color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey. -
Perfect comfort and flexibility for home and office
VT207N has multiple video and peripheral connectors, including VGA, DVI-D and USB, making it suitable for use anywhere, either in the home or at the office. VT207N features an elegant circular base with an ergonomically-designed tilting stand that lets you choose the ideal viewing position. The monitor is also VESA mount-compatible, making it easy to mount on a wall or monitor arm. Advanced power-saving features ensure low energy costs and maximum reliability.
- ASUS VT207N - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5" - touchscreen
- Power Consumption (On mode)
- 14.8 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.27 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Black
- Dimensions (WxDxH) - without stand
- 48.07 cm x 4.5 cm x 29.61 cm
- 2.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, EAC, China Energy Label
- Display Type
- 14.8 W
- Diagonal Size
- 19.5"
- Viewable Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.27 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Colour temperature
- HDCP, Skin-Tone Selection, glare, ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, ASUS QuickFit Virtual Scale, 10-point multi-touch
- Black
- 48.07 cm x 4.5 cm x 29.61 cm - without stand
- 2.9 kg
Input
- Touchscreen
- VGA , DVI-D , USB 2.0 (Type B)
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Flat Panel Mount Interface
- 75 x 75 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x USB cable
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 16.4 Watt
- Power Consumption Stand by
- 0.2 Watt
- Power Consumption Sleep
- 0.14 Watt
- Dimensions & Weight Details
- With stand - width: 48.07 cm - depth: 19.99 cm - height: 36.116 cm
- ENERGY STAR Certified
