Asus VT207N 19.5" 1600x900 5ms VGA DVI LED Touchscreen Monitor
Quicklinx: 9TQ5WS00 Mfr#: VT207N
Experience stunning visuals on this great touchscreen display with ASUS Smart Contrast Ratio and fast response time. Simply tap, drag, pinch, zoom or spin with your fingers for an amazingly natural and effortless touch experience.
  • An incredibly intuitive touch experience
    The ASUS VT207N touchscreen monitor combines multi-touch capability with great image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display allows you to work smarter and more efficiently.
  • Stunningly vivid display
    The ASUS VT207N has a 19.5-inch widescreen display that delivers outstanding image quality thanks to its HD 1600 x 900 resolution and ASUS Smart Contrast Ratio (ASCR). With a fast response time, you'll get pin-sharp images for any kind of content. And you can also choose your preferred aspect ratio for scaling non-widescreen images via the aspect ratio control.
  • The touchscreen monitor that gives you much more
    ASUS QuickFit Virtual Scale's onscreen alignment grid overlay helps you align and preview actual-size photos and documents on screen prior to printing, making sure they print perfectly every time. ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the great color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey.
  • Perfect comfort and flexibility for home and office
    VT207N has multiple video and peripheral connectors, including VGA, DVI-D and USB, making it suitable for use anywhere, either in the home or at the office. VT207N features an elegant circular base with an ergonomically-designed tilting stand that lets you choose the ideal viewing position. The monitor is also VESA mount-compatible, making it easy to mount on a wall or monitor arm. Advanced power-saving features ensure low energy costs and maximum reliability.
ASUS VT207N - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5" - touchscreen
Power Consumption (On mode)
14.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
48.07 cm x 4.5 cm x 29.61 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, EAC, China Energy Label
Display Type
14.8 W
Diagonal Size
19.5"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Colour temperature
HDCP, Skin-Tone Selection, glare, ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, ASUS QuickFit Virtual Scale, 10-point multi-touch
48.07 cm x 4.5 cm x 29.61 cm - without stand
2.9 kg
Input
Touchscreen
VGA , DVI-D , USB 2.0 (Type B)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
1 x VGA cable , 1 x DVI cable , 1 x USB cable
Power Supply
Internal
16.4 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
0.14 Watt
Dimensions & Weight Details
With stand - width: 48.07 cm - depth: 19.99 cm - height: 36.116 cm
ENERGY STAR Certified
