Delicate touches make a monitor truly great, VS24AH 1920 x 1200 IPS LED monitor, with16:10 aspect ratio, 80,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
80,000,000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
178° ultra wide viewing angle
VS24AH adopts 178° (H)/178° (V) ultra wide viewing angle IPS panel that eliminates color shift on your screen no matter where and how you look at it. -
QuickFit virtual scale
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. -
Aspect control function
Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (scenery, theater, game, night view, sRGB and standard) can be selected via a hotkey.
- ASUS VS24AH - LED monitor - 24.1"
- LED-backlit LCD monitor - 24.1"
- Energy Class
- Class A+
- Energy Consumption per Year
- 25.1 kWh
- Power Consumption (On mode)
- 17.2 W
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Black
- 56.16 cm x 20.55 cm x 44.09 cm
- 4.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, FCC, RoHS, WEEE, PSE Mark, J-MOSS, ERP
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 25.1 kWh
- Diagonal Size
- 24.1"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 61 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, input select, colour temperature, aspect control
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ultra wide viewing angle, ASUS QuickFit Virtual Scale, Slim Design
- Black
- 56.16 cm x 20.55 cm x 44.09 cm - with stand
- 4.6 kg
- VGA , DVI-D , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable, tilt adjustment
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- 17.2 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
