Asus VS247HR 23.6" 1920x1080 2ms VGA DVI HDMI LED Monitor
Quicklinx: 9TP7WS00 Mfr#: VS247HR
Delicate touches make a monitor truly great, VS247HR Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
  • Superior image quality meets classic elegant design
  • 50,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Full HD with HDMI
    Enter a spectacular world of colors with Full HD 1080p (1920 x 1080) support and HDMI port.
  • Aspect control function
    Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey.
ASUS VS247HR - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
56.18 cm x 20 cm x 41.06 cm
4.2 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, EK, FCC, RoHS, WEEE, J-MOSS, ErP Ready
3-year warranty
Display Type
Energy Class
Class A
33 kWh
22 W
Diagonal Size
23.6"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, input select, colour temperature, aspect control
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode
4.2 kg
VGA , DVI-D , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
22.7 Watt
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
9TP7 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £110.60
9TP7 StarTech.com Articulating Monitor Arm In Stock £89.19
9TP7 StarTech.com Dual Monitor Stand In Stock £70.09
9TP7 StarTech.com Cubicle Monitor Hanger In Stock £45.76
9TP7 StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
