Delicate touches make a VS229NA Full HD LED monitor truly great with 80,000,000:1 high contrast ratio is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
ASUS Smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
Full HD
Enter a spectacular world of colors with Full HD 1080p support. -
17° ultra wide viewing angle
VS229NA adopts 178°(H) / 178°(V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it. -
Aspect control function
Aspect control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
Splendid video intelligence technology
The exclusive Splendid video intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. Featuring two modes - Reading and Darkroom - in addition to the Scenery, Standard, Theater, and sRGB modes. Low-blue light technologies also reduce the strain on your eyes after long-time usage. -
QuickFit virtual scale (patent-pending)
The ASUS-exclusive QuickFit built in the monitor provides real-size photo and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. -
Stylish and user-friendly design for modern sophistication
This product has convenient key controls for functional set-up in the multi-language OSD, it also has easily detachable base for wall mount. -
Greener materials
It is made from environmentally-friendly material - Mercury-free LED-backlit panel, corrugated cardboard packaging with at least 80% recycled content. Besides, slim-flat packaging allows more cartons to be fitted per cargo, reducing transportation costs and carbon dioxide emission.
- ASUS VS229NA - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 26.4 kWh
- Power Consumption (On mode)
- 18.1 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.41 cm x 20.063 cm x 38.722 cm
- 3.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, J-MOSS, ErP Ready, EAC, CEL level 1
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 26.4 kWh
- Diagonal Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, colour temperature, aspect control
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale
- Black
- 51.41 cm x 20.063 cm x 38.722 cm - with stand
- 3.5 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Input Voltage
- 18.1 W
- Power Consumption (Typical)
- 30 watt
- Power Consumption Stand by
- 0.5 watt
- Power Consumption Sleep
- 0.5 watt
- Dimensions & Weight Details
- Without stand - width: 51.41 cm - depth: 4.84 cm - height: 31.518 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £9.15 |
