Asus VS228NE 21.5" 1920x1080 5ms VGA DVI LED Monitor
Quicklinx: 9TQ3WS00 Mfr#: VS228NE
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: [N/A]
Interfaces: DVI, VGA (HD-15)
Hurry, only 1 left in stock!
£89.12 ex VAT
£106.94 inc VAT
VS228NE Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDCP support, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
When you would like to watch movies upward lying down, Smart View technology can adjust color parameters to deliver the same image quality and colors with straight viewing. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey.
  • Superior image quality meets classic elegant design
  • 50,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Full HD 1080p support
    Enter a spectacular world of colors with Full HD 1080p (1920 x 1080) support.
  • Versatile viewing positions with Smart View technology
  • Aspect control function
    Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Splendid Video Intelligence technology
ASUS VS228NE - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
51.41 cm x 20 cm x 38.63 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, EK, FCC, RoHS, WEEE, PSE Mark, GOST-R, J-MOSS, ErP Ready
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, colour temperature, aspect control
HDCP, ASUS Splendid Video Intelligence Technology, anti-glare, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology
51.41 cm x 20 cm x 38.63 cm - with stand
3.8 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, tilt adjustment
1 x VGA cable , 1 x DVI cable
25 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus VS228NE 21.5 Bundle deal on Asus VS228NE 21.5" 1920x1080 5ms VGA DVI LED Monitor
£188.29
9TQ3 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.91
9TQ3 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £11.09
9TQ3 C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.80
9TQ3 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
9TQ3 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.60
Response Time: 5ms
Speakers: [N/A]
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 50 - 100
