Asus VS197DE 18.5" 1366x768 5ms VGA Black Monitor
Quicklinx: 92TYWS00 Mfr#: VS197DE
Diagonal Size: 18.5in
Max Resolution: 1366 x 768
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
£55.50 ex VAT
£66.60 inc VAT
VS197DE LED monitor with 50,000,000:1 high contrast ratio, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
  • 50,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Excellent visual performance
    Indulge your visual senses with 1366x768 resolution and 5ms quick response time for work and entertainment. The best dual-display companion with your widescreen notebook enlarges the visual space for multi-tasking efficiency. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Versatile viewing positions with Smart View Technology
    When you would like to watch movies upward lying down, Smart View Technology can adjust color parameters to deliver the same image quality and colors with straight viewing.
  • Splendid Video Intelligence Technology
    The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
ASUS VS197DE - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Energy Class
Class F
Power Consumption (On mode)
15.7 W
Aspect Ratio
16:9
Native Resolution
1366 x 768
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
44.7 cm x 18.5 cm x 34.6 cm
2.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, EK, FCC, RoHS, WEEE, GOST-R, J-MOSS, EuP Ready
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
18.5"
Viewable Size
18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, colour temperature, aspect control
sRGB colour management, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology
2.6 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
15.7 W
15.7 kWh/1000h
Power Consumption (Typical)
17 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.3 Watt
Power Consumption Sleep
0.25 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Response Time: 5ms
Speakers: None
Brand: Asus
