VP247H 23.6" Full HD monitor with high contrast ratio, ASUS SplendidPlus and VivdPixel technologies are optimized for fine image and color quality. This approach extends to the study stand and slim profile without compromising style in ensuring stability and durability. ASUS Smart Contrast Ratio dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback.
Superior image quality meets classic elegant design
VP247H 23.6" Full HD monitor with high contrast ratio, ASUS SplendidPlus and VivdPixel technologies are optimized for fine image and color quality. This approach extends to the study stand and slim profile without compromising style in ensuring stability and durability. -
ASUS Smart Contrast Ratio dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
1 ms response time
Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback. -
ASUS GamePlus technology
When it comes to design, ASUS has customers in mind - the ASUS VP247H features the ASUS GamePlus hotkey with crosshair and timer functions. Gamers can select four different crosshair types to suit the gaming environment; while the latter keeps players aware of the elapsed time in real-time strategy games. These tools allow gamers to practice and improve on their gaming skills. -
ASUS SplendidPlus technologies
The VP247H features the SplendidPlus Video Intelligence technology that optimizes videos and images by enhancing color brightness, contrast, and sharpness. SplendidPlus features two modes - Reading and Darkroom - in addition to the Scenery, Standard, Theater, sRGB, and Night View modes. Low-blue Light and Flicker-free technologies also reduce the strain on your eyes after long periods of use. -
VividPixel technology for amazing picture quality
ASUS VividPixel technology helps enhance image outlines and reduce noise bars for crystal-clear and detail-oriented viewing. -
Flicker-free technology
Say goodbye to tired, strained eyes. The VP247H features the Flicker-free technology designed to reduce flicker for a comfortable viewing experience. This minimizes instances of eyestrain and other damaging effects when you spend long, countless hours in front of a display.
- ASUS VP247H - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Class
- Class B
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 26 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.11 cm x 19.94 cm x 40.01 cm
- 4 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, MEPS, J-MOSS, ErP Ready, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 38 kWh
- Diagonal Size
- 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, input select
- HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
- Black
- 56.11 cm x 19.94 cm x 40.01 cm - with stand
- 4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- HDMI , VGA , DVI-D , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26 W
- Power Consumption (Typical)
- 22.7 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 56.11 cm - depth: 5.17 cm - height: 33.58 cm , With stand - width: 56.11 cm - depth: 19.94 cm - height: 40.01 cm - weight: 4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
