Product
Brand
Asus VP247H 23.6" 1920 x 1080 1ms HDMI DVI LED Monitor
Quicklinx: CYS9WS00 Mfr#: VP247H
VP247H 23.6" Full HD monitor with high contrast ratio, ASUS SplendidPlus and VivdPixel technologies are optimized for fine image and color quality. This approach extends to the study stand and slim profile without compromising style in ensuring stability and durability. ASUS Smart Contrast Ratio dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback.
ASUS VP247H - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
56.11 cm x 19.94 cm x 40.01 cm
4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, MEPS, J-MOSS, ErP Ready, TCO Displays 6.0, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification
3 years warranty
Display Type
Energy Class
Class B
38 kWh
26 W
Diagonal Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, input select
HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
56.11 cm x 19.94 cm x 40.01 cm - with stand
4 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
HDMI , VGA , DVI-D , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
22.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.11 cm - depth: 5.17 cm - height: 33.58 cm , With stand - width: 56.11 cm - depth: 19.94 cm - height: 40.01 cm - weight: 4 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
