Asus VP228TE 21.5" 1920x1080 1ms DVI VGA Black with Speakers
Quicklinx: C49VWS00 Mfr#: VP228TE
Sorry but this product has been discontinued.
View used stock
VP228TE 21.5" Full HD monitor with 100,000,000:1 high contrast ratio, ASUS-exclusive SplendidPlus and VivdPixel technologies is optimized for the finest image and color quality. This approach extends to the study stand and slim profile without compromising style in ensuring stability and durability.
  • Superior image quality meets classic elegant design
  • 100,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • 1ms quick response time
    1ms (GTG) quick response time eliminates ghosting and tracers for more fluid video playback.
  • ASUS-exclusive GamePlus technology
    When it comes to design, ASUS always have customers in mind - the ASUS VP228TE features the ASUS-exclusive GamePlus hotkey with crosshair and timer functions. Gamers can select four different crosshair types to suit the gaming environment; while the latter keeps players aware of the elapsed time in real-time strategy games. These tools allow gamers to practice and improve on their gaming skills.
  • VividPixel technology for best picture quality
    ASUS VividPixel Technology helps enhance image outlines and reduce noise bars for crystal-clear and detail-oriented viewing.
  • Flicker-free technology
    Say goodbye to tired, strained eyes. The VP228TE features theTÜV Rheinland-certified ASUS Flicker-Free technology designed to reduce flicker for a comfortable viewing experience. This minimizes instances of eyestrain and other damaging effects when you spend long, countless hours in front of a display.
  • ASUS blue light filter
    The VP228TE also comes with the TÜV Rheinland-certified ASUS Blue Light Filter to protect you from harmful blue light; a new OSD menu lets you easily access and select four different filter settings onscreen.
ASUS VP228TE - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
51.3 cm x 19.94 cm x 7.3 cm
3.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, PSE Mark, MEPS, J-MOSS, ErP Ready, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification
3-year warranty
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, colour temperature
HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology, Blue Light Filter technology
51.3 cm x 19.94 cm x 7.3 cm - with stand
3.5 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
Audio line-in , VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Security Slot Type
Kensington security slot
21.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
Without stand - width: 51.3 cm - depth: 5.21 cm - height: 30.9 cm , With stand - width: 51.3 cm - depth: 19.94 cm - height: 7.3 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
C49V C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.91
C49V C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.25
C49V C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.78
C49V C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
C49V C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.57
C49V C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.60
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: C49V 040466
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £71.27
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
