Asus VP228HE 21.5" 1920 x 1080 1ms HDMI VGA LED Monitor
Quicklinx: CYSBWS00 Mfr#: VP228HE
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
£77.54 ex VAT
£93.04 inc VAT
VP228HE 21.5" Full HD monitor with 100000000:1 high contrast ratio, ASUS-exclusive SplendidPlus and VivdPixel technologies is optimized for the fine image and color quality. This approach extends to the sturdy stand and slim profile, without compromising style in ensuring stability and durability.
  • ASUS-exclusive GamePlus technology
    When it comes to design, ASUS always have customers in mind - the ASUS VP228HE features the ASUS-exclusive GamePlus hotkey with crosshair and timer functions. Gamers can select four different crosshair types to suit the gaming environment; while the latter keeps players aware of the elapsed time in real-time strategy games. These tools allow gamers to practice and improve on their gaming skills.
  • ASUS-exclusive SplendidPlus technologies
    The VP228HE features the SplendidPlus video intelligence technology, that optimizes videos and images by enhancing color brightness, contrast, and sharpness. SplendidPlus features two additional modes - Reading and Darkroom - in addition to the Scenery, Standard, Theater, sRGB, and Night View modes. Low blue light and Flicker-free technologies also reduce the strain on your eyes after long periods of use.
  • VividPixel technology for optimal picture quality
    ASUS VividPixel technology helps enhance image outlines and reduce noise bars for crystal-clear and detail-oriented viewing.
ASUS VP228HE - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
51.3 cm x 19.94 cm x 37.3 cm
3.5 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, WEEE, PSE Mark, MEPS, J-MOSS, ErP Ready, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology, Blue Light Filter technology, Colour Temperature Selection
51.3 cm x 19.94 cm x 37.3 cm - with stand
3.5 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
HDMI , VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Security Slot Type
Kensington security slot
21.1 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 51.3 cm - depth: 5.21 cm - height: 30.9 cm , With stand - width: 51.3 cm - depth: 19.94 cm - height: 37.3 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus VP228HE 21.5 Bundle deal on Asus VP228HE 21.5" 1920 x 1080 1ms HDMI VGA LED Monitor
£176.71
CYSB StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.78
CYSB StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £110.60
CYSB StarTech.com Dual Monitor Stand In Stock £70.09
CYSB StarTech.com Monitor Arm - Heavy Duty In Stock £73.54
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 50 - 100
