VN289 with wide viewing angle and SplendidPLUS mode adopts Flicker-Free technology by DC adjustment backlighting, which clears the annoying flicker and brings comfort viewing experience.
- ASUS VN289H - LED monitor - Full HD (1080p) - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class A
- Energy Consumption per Year
- 47 kWh
- Power Consumption (On mode)
- 32.2 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.32 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Speakers
- Integrated
- Tilt
- Black
- 66.02 cm x 21 cm x 45.07 cm
- 5.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, MEPS, ERP, CEL level 1
- Display Type
- Energy Class
- Class A
- 47 kWh
- Diagonal Size
- 28"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.32 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, colour temperature
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ultra wide viewing angle, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, EyeCare Utility, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology
- Black
- 66.02 cm x 21 cm x 45.07 cm - with stand
- 5.4 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- Audio line-in , Headphones , HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- 32.2 W
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 66.02 cm - depth: 6.37 cm - height: 38.07 cm
Sustainability Information
- ENERGY STAR Certified
