Your basket is empty
Asus VN289H 28" Wide LED 1920 x 1080 16:9 VESA FullHD 5ms HDMI, VGA, Speakers, Black
Quicklinx: 9L1DWS00 Mfr#: VN289H
VN289 with wide viewing angle and SplendidPLUS mode adopts Flicker-Free technology by DC adjustment backlighting, which clears the annoying flicker and brings comfort viewing experience.
ASUS VN289H - LED monitor - Full HD (1080p) - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class A
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32.2 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
66.02 cm x 21 cm x 45.07 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, MEPS, ERP, TCO Displays 6.0, CEL level 1
Display Type
Energy Class
Class A
47 kWh
32.2 W
Diagonal Size
28"
Viewable Size
28"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ultra wide viewing angle, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, EyeCare Utility, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology
66.02 cm x 21 cm x 45.07 cm - with stand
5.4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Audio line-in , Headphones , HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
35 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
Without stand - width: 66.02 cm - depth: 6.37 cm - height: 38.07 cm
ENERGY STAR Certified
9L1D C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9L1D C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
9L1D C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
9L1D C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
9L1D C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
9L1D C2G Pro HDMI to VGA Converter In Stock £46.35
