Asus VN279QLB 27" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: 9TNMWS00 Mfr#: VN279QLB
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
Hurry, only 3 left in stock!
£216.43 ex VAT
£259.71 inc VAT
The ASUS VN series features compact dimensions - this 27" display has a super narrow bezel of just 0.8 cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN279QLB is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution.
  • Experience a multi-screen solution with a super narrow frame
  • Full HD with DisplayPort and HDMI inputs
    VN279QLB leads you to enter a big and spectacular world of colors with Full HD 1080p (1920 x 1080) support and rich connectivity including DisplayPort, HDMI/MHL and D-sub inputs
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness.
  • Smart contrast ratio for lifelike visuals
    With 100,000,000:1 ASUS Smart Contrast Ratio (ASCR), the VN279QLB enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
  • ASUS exclusive QuickFit virtual scale
    ASUS includes its exclusive QuickFit virtual scale feature with the VN279QLB, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
  • Extensive connectivity and built-in stereo speakers for multimedia enjoyment
    VN279QLB comes with rich connectivity including 2 x USB 3.0, DisplayPort. HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
ASUS VN279QLB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35.2 kWh
Power Consumption (On mode)
24.1 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
61.92 cm x 22.55 cm x 52.6 cm
6.1 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, J-MOSS, UkrSEPRO, CEL
3-year warranty
Display Type
Energy Class
Class A
35.2 kWh
24.1 W
Diagonal Size
27"
Viewable Size
27"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 67.5 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ultra wide viewing angle, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, super narrow frame
61.92 cm x 22.55 cm x 52.6 cm - with stand
6.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Microphone , Headphones , HDMI , VGA , DisplayPort , USB upstream , 2 x USB downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
160
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x audio cable , 1 x SuperSpeed USB cable
35 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus VN279QLB 27 Bundle deal on Asus VN279QLB 27" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
£315.60
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 150 - 300
