Asus VN279QL 27" 1920x1080 5ms HDMI VGA Monitor
Quicklinx: CW2HWS00 Mfr#: VN279QL
The ASUS VN series features compact dimensions - this 27" display has a super narrow bezel, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN279QL is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution.
The VN279QL enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
  • Experience a multi-screen solution with a super narrow frame
  • Full HD with DisplayPort and HDMI inputs
    VN279QL leads you to enter a big and spectacular world of colors with Full HD 1080p (1920 x 1080) support and rich connectivity including DisplayPort, HDMI/MHL and D-sub inputs.
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey.
  • Smart Contrast Ratio for lifelike visuals
  • ASUS exclusive QuickFit Virtual Scale
    ASUS includes its exclusive QuickFit Virtual Scale feature with the VN279QL, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
  • Versatile comfort with ergonomic design
    The ergonomically-designed VN279QL monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
  • Extensive connectivity and built-in stereo speakers for multimedia enjoyment
    VN279QL comes with rich connectivity including DisplayPort. HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
ASUS VN279QL - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours (8-bit)
Input Connectors
HDMI, VGA, MHL, DisplayPort
Speakers
Integrated
Display Position Adjustments
61.92 cm x 22.55 cm x 5.26 cm
6.1 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, J-MOSS, UkrSEPRO, EAC, CEL level 1, CU
Display Type
Diagonal Size
27"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 67.5 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ultra wide viewing angle, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, super narrow frame
61.92 cm x 22.55 cm x 5.26 cm - with stand
6.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Microphone , Headphones , MHL / HDMI , VGA , DisplayPort
Mechanical
Tilt Angle
-5/+22
Swivel Angle
160
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Security Slot Type
Kensington security slot
Power Consumption (Typical)
35 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.92 cm - depth: 22.55 cm - height: 5.26 cm - weight: 6.1 kg , Without stand - width: 61.92 cm - depth: 4.83 cm - height: 36.24 cm
Shipping Width
71.5 cm
Shipping Depth
20 cm
Shipping Height
44.9 cm
Shipping Weight
8.3 kg
Sustainability Information
ENERGY STAR Certified
