The ASUS VN series features compact dimensions - this 27" display has a super narrow bezel, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN279QL is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution.
The VN279QL enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
Experience a multi-screen solution with a super narrow frame
The ASUS VN series features compact dimensions - this 27" display has a super narrow bezel, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN279QL is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution. -
Full HD with DisplayPort and HDMI inputs
VN279QL leads you to enter a big and spectacular world of colors with Full HD 1080p (1920 x 1080) support and rich connectivity including DisplayPort, HDMI/MHL and D-sub inputs. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey. -
Smart Contrast Ratio for lifelike visuals
The VN279QL enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. -
ASUS exclusive QuickFit Virtual Scale
ASUS includes its exclusive QuickFit Virtual Scale feature with the VN279QL, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size. -
Versatile comfort with ergonomic design
The ergonomically-designed VN279QL monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. -
Extensive connectivity and built-in stereo speakers for multimedia enjoyment
VN279QL comes with rich connectivity including DisplayPort. HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
- ASUS VN279QL - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours (8-bit)
- Input Connectors
- HDMI, VGA, MHL, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Black
- 61.92 cm x 22.55 cm x 5.26 cm
- 6.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, J-MOSS, UkrSEPRO, EAC, CEL level 1, CU
- Display Type
- Diagonal Size
- 27"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 67.5 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, colour temperature
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ultra wide viewing angle, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, super narrow frame
- Black
- 61.92 cm x 22.55 cm x 5.26 cm - with stand
- 6.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- Microphone , Headphones , MHL / HDMI , VGA , DisplayPort
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 160
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- Power Consumption (Typical)
- 35 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 61.92 cm - depth: 22.55 cm - height: 5.26 cm - weight: 6.1 kg , Without stand - width: 61.92 cm - depth: 4.83 cm - height: 36.24 cm
- Shipping Width
- 71.5 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 44.9 cm
- Shipping Weight
- 8.3 kg
Sustainability Information
- ENERGY STAR Certified
