The ASUS VN series features compact dimensions - this 23.8" display has a super narrow bezel of just 1cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN248QA is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution.
The ASUS VN248QA features In-Plane Switching display technology for superior color accuracy, a brighter image from increased backlight transmission and lower power consumption. VN248QA leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support.
The exclusive SplendidPlus Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 8 preset video modes (Reading, Darkroom, Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
ASUS VividPixel Technology helps enhance image outlines and reduce noise bars for crystal-clear and detail-oriented viewing.
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the VN248QA enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
ASUS includes its exclusive QuickFit Virtual Scale feature with the VN248QA, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
VN248QA comes with rich connectivity including Displayport, HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
Experience a Multi-screen solution with a super narrow frame
The ASUS VN series features compact dimensions - this 23.8" display has a super narrow bezel of just 1cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN248QA is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution. -
178° wide viewing angle in-plane switching technology
The ASUS VN248QA features In-Plane Switching display technology for superior color accuracy, a brighter image from increased backlight transmission and lower power consumption. -
Full HD with spectacular images
VN248QA leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support. -
SplendidPlus Video Intelligence technology
The exclusive SplendidPlus Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 8 preset video modes (Reading, Darkroom, Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey. -
Reading mode
Creating comfortable experience as if reading actual books by adjusting the monitor's color temperature and reducing blue light levels, simulating paperback books. -
Darkroom mode
Best for soft ambient light environment by reducing blue light for visual pleasure. -
VividPixel technology for best picture quality
ASUS VividPixel Technology helps enhance image outlines and reduce noise bars for crystal-clear and detail-oriented viewing. -
Monitors without VividPixel
Blur happens if the original image is in low resolution. -
Monitors with VividPixel
VividPixel generates high-quality images on screen. -
Smart Contrast Ratio for lifelike visuals
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the VN248QA enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. -
ASUS Exclusive QuickFit Virtual Scale
ASUS includes its exclusive QuickFit Virtual Scale feature with the VN248QA, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size. -
Extensive connectivity and built-in stereo speakers for multimedia enjoyment
- ASUS VN248QA - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Speakers
- Integrated
- Tilt
- Black
- 55.45 cm x 19.42 cm x 39.3 cm
- 4 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, Green Mark, ErP Ready
- 3-year warranty
- Display Type
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, input select, colour temperature
- sRGB colour management, HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, super narrow frame, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology
- Black
- 55.45 cm x 19.42 cm x 39.3 cm - with stand
- 4 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- Audio line-in (mini-jack) , DisplayPort , HDMI , VGA , Headphones (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Power Supply
- Internal
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 55.45 cm - depth: 19.42 cm - height: 39.3 cm - weight: 4 kg , Without stand - width: 55.45 cm - depth: 4.73 cm - height: 32.89 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
