Your basket is empty
Asus VN248QA 23.8" 1920x1080 5ms VGA HDMI DP IPS Monitor
Quicklinx: BJWLWS00 Mfr#: VN248QA
The ASUS VN series features compact dimensions - this 23.8" display has a super narrow bezel of just 1cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN248QA is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution.
The ASUS VN248QA features In-Plane Switching display technology for superior color accuracy, a brighter image from increased backlight transmission and lower power consumption. VN248QA leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support.
The exclusive SplendidPlus Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 8 preset video modes (Reading, Darkroom, Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
ASUS VividPixel Technology helps enhance image outlines and reduce noise bars for crystal-clear and detail-oriented viewing.
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the VN248QA enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
ASUS includes its exclusive QuickFit Virtual Scale feature with the VN248QA, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
VN248QA comes with rich connectivity including Displayport, HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
ASUS VN248QA - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
55.45 cm x 19.42 cm x 39.3 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, Green Mark, ErP Ready, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
sRGB colour management, HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, super narrow frame, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology
55.45 cm x 19.42 cm x 39.3 cm - with stand
4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Audio line-in (mini-jack) , DisplayPort , HDMI , VGA , Headphones (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Power Supply
Internal
23 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 55.45 cm - depth: 19.42 cm - height: 39.3 cm - weight: 4 kg , Without stand - width: 55.45 cm - depth: 4.73 cm - height: 32.89 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
