VN247HA leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including dual HDMI and D-sub inputs. With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR), the VN247HA enhances display contrast and sharpness by adjusting backlight luminance to achieve deep black tones and bright whites, resulting in extra-clear visuals that truly come to life.
Experience a multi-screen solution with a super narrow frame
The ASUS VN series features compact dimensions - this 23.6" display has a super narrow bezel bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN247HA is also VESA wall mount compatible. -
Full HD with dual HDMI and D-sub inputs
VN247HA leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including dual HDMI and D-sub inputs. -
178-degree ultra wide viewing angle
VN247HA adopts 178°(H) / 178°(V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it. -
Smart Contrast Ratio for lifelike visuals
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR), the VN247HA enhances display contrast and sharpness by adjusting backlight luminance to achieve deep black tones and bright whites, resulting in extra-clear visuals that truly come to life. -
Aspect Control function
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
Extensive connectivity and built-in stereo speaker for multimedia enjoyment
VN247HA comes with rich connectivity including dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. -
Reading mode
Creating comfortable experience as if reading actual books by adjusting the monitor's color temperature and brightness levels, simulating paperback books.QuickFit Virtual ScaleASUS includes its exclusive QuickFit Virtual Scale feature with the VN247HA, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
- ASUS VN247HA - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Class
- Class A
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 21 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Speakers
- Integrated
- Tilt
- Black
- 54.86 cm x 19.42 cm x 39.49 cm
- 3.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, GOST-R
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 30 kWh
- Diagonal Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, input select, colour temperature, aspect control
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, super narrow frame, Low Blue Light Mode, Reader Mode
- Black
- 54.86 cm x 19.42 cm x 39.49 cm - with stand
- 3.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- 2 x HDMI , VGA , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x HDMI-DVI cable
- Power Supply
- Internal
- 21 W
- Power Consumption (Typical)
- 22.7 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 54.86 cm - depth: 4.32 cm - height: 32.2 cm , With stand - width: 54.86 cm - depth: 19.42 cm - height: 39.49 cm - weight: 3.8 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
