Product
Asus VN247HA 23.6" 1920x1080 5 ms HDMI VGA Monitor
Quicklinx: CW2LWS00 Mfr#: VN247HA
Diagonal Size: 23.6in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
£130.32 ex VAT
£156.38 inc VAT
VN247HA leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including dual HDMI and D-sub inputs. With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR), the VN247HA enhances display contrast and sharpness by adjusting backlight luminance to achieve deep black tones and bright whites, resulting in extra-clear visuals that truly come to life.
  • Experience a multi-screen solution with a super narrow frame
    The ASUS VN series features compact dimensions - this 23.6" display has a super narrow bezel bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN247HA is also VESA wall mount compatible.
  • Full HD with dual HDMI and D-sub inputs
  • 178-degree ultra wide viewing angle
    VN247HA adopts 178°(H) / 178°(V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it.
  • Smart Contrast Ratio for lifelike visuals
  • Aspect Control function
    Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Extensive connectivity and built-in stereo speaker for multimedia enjoyment
    VN247HA comes with rich connectivity including dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness.
  • Reading mode
    Creating comfortable experience as if reading actual books by adjusting the monitor's color temperature and brightness levels, simulating paperback books.QuickFit Virtual ScaleASUS includes its exclusive QuickFit Virtual Scale feature with the VN247HA, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
ASUS VN247HA - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
21 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
54.86 cm x 19.42 cm x 39.49 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, GOST-R
3 years warranty
Display Type
Energy Class
Class A
30 kWh
21 W
Diagonal Size
23.6"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature, aspect control
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, super narrow frame, Low Blue Light Mode, Reader Mode
54.86 cm x 19.42 cm x 39.49 cm - with stand
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
2 x HDMI , VGA , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable , 1 x HDMI-DVI cable
Power Supply
Internal
22.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 54.86 cm - depth: 4.32 cm - height: 32.2 cm , With stand - width: 54.86 cm - depth: 19.42 cm - height: 39.49 cm - weight: 3.8 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus VN247HA 23.6 Bundle deal on Asus VN247HA 23.6" 1920x1080 5 ms HDMI VGA Monitor
£227.31
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 100 - 150
