The ASUS VN series features compact dimensions- this 23.6" display has a super narrow bezel, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratchproof. The VN247H is also VESA wall mount compatible, and has the capabilities to be a stunning multi-screen solution.
Full HD with dual HDMI and D-sub inputs
VN247H leads you to enter a big and spectacular world of colors with Full HD 1080p support and rich connectivity including dual HDMI and D-sub inputs. -
Ultra-fast response time
An ultra-fast gray-to-gray response time and Trace Free technology deliver realistic moving visuals and a blur-free multimedia experience. -
Smart Contrast Ratio for lifelike visuals
With ASUS Smart Contrast Ratio (ASCR), the VN247H enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. -
Aspect control function
Aspect control function allows users to select a preferred display mode for true-to-life gaming or movie watching without any data loss or image distortion. -
Extensive connectivity and built-in stereo speaker for multimedia enjoyment
VN247H comes with rich connectivity including HDMI and D-sub so that users could easily connect to Full HD Blu-ray players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. Several preset video modes can be selected via a hotkey. -
QuickFit Virtual Scale
ASUS includes its QuickFit Virtual Scale feature with the VN247H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
- ASUS VN247H - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Speakers
- Integrated
- Tilt
- Black
- 54.86 cm x 19.42 cm x 39.4 cm
- 3.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, GOST-R
- 3-year warranty
- Display Type
- Diagonal Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, colour temperature, aspect control
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
- Black
- 54.86 cm x 19.42 cm x 39.4 cm - with stand
- 3.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- Microphone , Headphones , 2 x HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable, anti-scratch
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x HDMI-DVI cable
- Power Consumption (Typical)
- 22.7 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
